It is currently Sat Oct 31, 2026 2:27 pm
Post Posted: Sun Dec 08, 2013 10:30 pm
I'm changing the clutch in my '92 Sierra, but can't get my transmission out of the car.
It's been disconnected from everything according to the workshop manual, but I can't get it to clear the support bracket on the chassis and the engine.
I've heard a few people cut or bend this bracket, or pull out their engine. I really don't want to do either, but have also spent close to an hour trying to find a way to drop it out without success.
How do you guys get this done?
Post Posted: Sun Dec 08, 2013 11:03 pm
need to rotate it 45 degrees or so towards the drivers side (or maybe the passenger side, can't remember :? ) but it drops out easily once the square top part of the bell housing can clear the clutch when it's over to one side.
Post Posted: Mon Dec 09, 2013 5:41 am
Trim 10mm off the front of the gearbox mount on the chassis.
Gearbox will fall out then.
Post Posted: Mon Dec 09, 2013 6:04 am
as per steve, rotate the gearbox and it will clear, its pretty light so its not to hard. I remember it as rotating the top towards the passenger side.
Post Posted: Tue Dec 10, 2013 7:12 pm
Rotating did the trick. Thanks guys.
I can see it'll be a bitch to get back on the motor, but that's future Rob's problem.
Users browsing this forum: Google [Bot] and 233 guests
