It is currently Mon Jun 08, 2026 10:22 am
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Dec 30, 2013 8:05 am
Hi Guys
based on your experiences getting things engineered or mod plated, what would be the best way to go with my Jimny.
in 8 months ill probably be moving back to Queensland. it has 3" springs, 2" BL, JB front arms, 30x9.5 km2's, the mounts and bar on the arb bullbar have been modified, along with the rear bar so taking out the BL is actually a fair deal of work.
can you get something 150mm over standard mod plated in Queensland or is it straight up engineering? id like to sort everything out over the phone and have the car booked in so it do sent get crushed...
Vehicle: 85 ' Drover
Post Posted: Mon Dec 30, 2013 1:22 pm
Ignore internet anicdotes.
Ring this guy.
http://www.modplate.com.au
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Dec 30, 2013 1:56 pm
thanks, but anecdotes is what i need. im sure both engineers and modplate certified mechanics will take my money just want to know if i have already crossed a line at 178mm overall lift...
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Dec 30, 2013 1:59 pm
and 60mm wider track. and no sway bar.
i just dont want to have to revert the car to stock to try and get over the boarder
and the exhaust, i think that will also be a problem...
Post Posted: Mon Dec 30, 2013 2:12 pm
You can get the BL mod plated..as for the rest, it's all outside of the realms of QLD laws. Tires and spring lift too big, front control arms and bar mounts, I don't think any copper or transport boffin would notice.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Dec 30, 2013 2:57 pm
engineering it is then. thanks
Post Posted: Mon Dec 30, 2013 3:31 pm
I still think you will struggle :(
Post Posted: Mon Dec 30, 2013 5:04 pm
Jezza86 wrote:
......... or is it straight up engineering?
What do you mean by engineering??
Post Posted: Mon Dec 30, 2013 5:25 pm
I think it's that thing every other state lets you do to mod your car....stupid QLD!!
Post Posted: Mon Dec 30, 2013 5:49 pm
That's what I thought. No such thing here
Post Posted: Mon Dec 30, 2013 5:52 pm
WA is pretty tight... you're allowed 50mm combined lift (tyres / body / spring) - after that it needs to be engineered, and anything taller than 150mm they won't consider. If its engineered it needs to do braking and lane change tests too. Plus there's a limit still on tyre size and track width increase! Makes it very hard to do anything half decent nowadays, as you can't just do a guard chop and run 31's on a sierra. IIRC the max size is a 29" tyre. I'm sure a jimny would be similar if not less due to weaker front diff?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Dec 30, 2013 5:57 pm
uhh. shit. this isnt looking good
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Jan 02, 2014 2:08 pm
reckon i can pass off a 3" lift as a 2"?
as then it would only be 2" of tires, 2" of springs, 2" of body... 150mm if i take some air out and chuck some bags of concrete in...
am i over reacting? i was home for chrissie and saw some other jimnys runing 30's but theyd all been bigjimny chopped not bodylifted.
Post Posted: Thu Jan 02, 2014 2:27 pm
don't tell them how lifted it is, just get them to measure the A-Pillar height compared to stock.... Just say "Lifted Springs".
Of course, if you happen to have some lead in the car to sink it down a bit, and maybe a little less pressure in the tyres that would help too... lol
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Jan 02, 2014 3:10 pm
haha yep. i figure ill get a mod plate for what i can i.e. body lift and then if the cops bother me it might be enough to convince them to go away.
then all ill need is mudflaps and something to quiet down that exhaust note.
Vehicle: 2011 Jimny
Post Posted: Thu Jan 02, 2014 5:33 pm
I've skim read your build and could only see that you put a body lift in to avoid chopping, correct? i dunno how wild you are offroad but i have very little scrubbing with just the 3" spring lift and 30's. only spot it rubs is the bottom front edge of the rear wheel arches which it looks like you have already trimmed.
Why not ditch the bodylift? the car wouldn't be as obvious, i haven't been pulled up as yet and the tires are the thing that people pick up on first.
example pics of my jim
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Jan 02, 2014 6:36 pm
trying to avoid ditching it as the bullbar, rearbar and sliders all suit +50mm, along with the steering shaft cos i modified that too..
i still get some scrub with the BL and i dont want to space the bumpstops reducing flexytimes.
think i have 8 months till the zook goes on the barge back to earth.
Post Posted: Wed Jan 08, 2014 12:48 am
Chuck standard springs back in, raise the shocks mounts, cut the guards and call it good pompoms
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Jan 08, 2014 7:05 am
see what happens. someone might shoot newman in the next 8 months
Vehicle: Sj70 tintop
Post Posted: Wed Jan 08, 2014 6:58 pm
not likely mate,
i removed the back seats when i lived in darwin, threw them in the bin, seat beslts and crap are still hanging in their.
cost me $150 to get it regoed in qld because as i had to get a mod plate because of the "changed the seating capacity" even though the seat belts were still in there. so basically removing 2 foam blocks that dont lay flat and can only hold kids up to the agge and size of 5 and sold as " seats" cost me $150 for the pleasure of removing them and having some flat useable space in the back.
than the mud flaps, FFS dont even get me started on the mud flaps, 6mm to long the first set were...........
still better than darwin!!!
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Jan 09, 2014 2:23 pm
i kept my back seets and trim for that exact purpose. i take out the draws, bury the power cables under the carpet, and the rest just bolts right in.
Users browsing this forum: No registered users and 14 guests
