It is currently Thu Oct 29, 2026 3:08 pm
Vehicle: Suzuki jimny, WT sierra, GTR.
Post Posted: Tue Dec 24, 2013 8:24 pm
Hi guys, I'm bolting on my driveshafts from a donor car to my project sierra and having a few dramas with the slip yoke. I have cleaned it pretty well but it is not fully compressing (only slides in about 50 mil or so and there is still a decent amount of yoke exposed before it gets stuck. Splines seem straight so I'm a little confused as to if this is normal or not or if I'm doing anything incorrectly. Thanks
Vehicle: Drover pickup turk
Post Posted: Tue Dec 24, 2013 8:40 pm
Do you put fresh grease on it?
I remember when I had mine out doing the unis I put fresh grease on the slip yoke and putting it back together I had a similar thing happen, Just push harder because you need to get the air out of the joint.
I like the tuna here
Post Posted: Tue Dec 24, 2013 9:16 pm
Yea, I put new grease on. There's air build up when I put it on but it's escaping and then it just stops abruptly and gets stuck. I have just gone out and poured kerosene into the female part of the yoke to loosen any debris inside. Ill leave it overnight and check back tommorow.
Post Posted: Thu Dec 26, 2013 4:20 pm
Still not moving, I'm just going too bolt it up. Maybe some flexing will free it up a bit haha
Vehicle: 92 sierra tintop, 88 WT sj50
Post Posted: Mon Dec 30, 2013 2:32 pm
Does it have a grease nipple on the end where the slip goes in?
Post Posted: Mon Jan 06, 2014 12:47 pm
Nope. I think the splines may be slightly bent. Seems to have cleared itself up after I started flexing her up.
Users browsing this forum: No registered users and 251 guests
