It is currently Mon Nov 02, 2026 9:49 pm
Vehicle: suzuki, jimny 1998
Post Posted: Thu Jan 09, 2014 5:46 pm
How hard is it going to be and what do I need to do it?
Has anyone doneit? tips would be awesome!
Vehicle: vit1990
Post Posted: Thu Jan 09, 2014 6:54 pm
You'll need the ecu & engine side of the loom from the donor car as well as the motor.
Assuming your car is a manual you'll also need an engine to gearbox/engine mount adapter kit. Trail tough do a good one. http://www.lowrangeoffroad.com/index.ph ... r-kit.html
You can use your gearbox and clutch. Obviously replace the clutch if it's worn.
Reuse the fan/shroud/radiator out of the Jimny.
A coil pack Baleno motor is your best bet, but being a transverse motor you'll need to adapt the radiator hoses. This can be done with a Swift thermostat cover.
You'll need to either modify a throttle cable or get a Maruti Gypsy cable. They're all Bowden style cables so easy enough to adapt.
Exhaust manifold should bolt up to the 1.6.
Vehicle: Sj51t
Post Posted: Thu Jan 09, 2014 8:12 pm
viewtopic.php?f=17&t=39217
Users browsing this forum: Google [Bot] and 109 guests
