It is currently Fri Jul 31, 2026 3:22 pm
Vehicle: LJ50 , LJ80Q-II
Post Posted: Fri Jan 24, 2014 11:37 am
hey guys
Any one running after market / or buckets seats in their LJ .
looking for options for my project as the old school fiberglass buckets I was given don't fit (back not upright enough which pushes the seat way to far forward)
Can anyone recommend Brands/Models to look at , or pics/dimensions of the seats used would be much appreciated
Post Posted: Fri Jan 24, 2014 11:41 am
I run OBX daytonas in my fiddy
i have a pair of sparco pro2000 to go in my LJ ute.
Post Posted: Fri Jan 24, 2014 11:49 am
Pro 2000's fit?
Lj's are a bitch to fit seats in. I know of a guy planning kirkeys because of fitment issues with regular seats.
Post Posted: Fri Jan 24, 2014 11:52 am
yep, i have the Drivers side one in.
they will be about 15mm apart in the middle of the car though :)
Post Posted: Fri Jan 24, 2014 12:43 pm
Cool, so I can use the dimensions of the Sparco Pro2000 as a theoretical maximum
Dimensions as follows
A: Bolsters Y Dia = 473mm
B: Shoulder Width = 576mm
C: Shoulder Height = 595mm
D: Cushion Width = 490mm
E: Cushion Depth = 520mm
G: Back Rest Projection = 115mm
Any chance of a pic of it fitted? I only measured 460mm clear between the tunnel and inner door lip . So I'm assuming that you have the seat sitting over the tunnel a bit .
Post Posted: Fri Jan 24, 2014 12:47 pm
They are up over the tunnel slightly, but the base actually sits lower than a standard seat.
Sorry dont have any pics for the seat mounted.
Users browsing this forum: No registered users and 346 guests
