| Author |
Message |
just_cruizin
Joined: Sun Jun 25, 2006 11:30 pm Posts: 2867 Location: here
 Posted: Sat Feb 01, 2014 10:35 pm |
I have a 2004 GV and would like to know more about fitting transfer case gears, problem is Low range only have gears to suit 2001 and before, apparently Suzuki changed the design due to the earlier cases jumping out of gear.
My question is will the early model transfer fit my 2004 or could I fit just the front half of the case?
_________________ greenzook89 wrote: 31zook wrote: Makes me want something similar
Built4thrashing
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
 Posted: Sun Feb 02, 2014 7:41 am |
The earlier transfer cases will bolt up to the later gearboxes and vice-a-versa.
The transfer gears will only change low range. High range is not altered.
Have you explored diff ratios options?......
just_cruizin
 Posted: Sun Feb 02, 2014 8:02 am |
Not as yet, probably the best option as ill have to change to vit diff centers if or when lockers are the go and to get rid of the auto engaging front
Built4thrashing
 Posted: Sun Feb 02, 2014 8:07 am |
just_cruizin wrote: Not as yet, probably the best option as ill have to change to vit diff centers if or when lockers are the go and to get rid of the auto engaging front I'd be swapping to 5.12 diffs first and get rid of the stupid air engagement front.... Quite a simple job to do.
zoukshin
Vehicle: 2004GV + bar + custom mods
 Posted: Mon Feb 03, 2014 11:27 am |
b4t, was told by a friend who is rebuilding an old cruiser with commodore bits (yeah I know, it starts off well) that modifying diffs has a lot of consequences. Apparently it's an art to recync all the gears to have your diff working properly after changing gears or rebuilding them. Can you elaborate ?
fordem
Joined: Mon Apr 19, 2010 11:30 pm Posts: 2659 Location: Georgetown, Guyana
 Posted: Mon Feb 03, 2014 12:21 pm |
I know of no issues resyncing gears when rebuilding diffs - just don't mix & match - if you replace one you replace all.
Having said that - setting up the ring & pinion (which technically speaking, is not a part of the differential) does require a fair degree of experience.
Built4thrashing
 Posted: Mon Feb 03, 2014 2:25 pm |
Ive done several diff rebuilds now and ive never had any issues.
The Front diff in the GV has been stripped and had the internals changed.
Steel housing and carrier, Vitara internal hemisphere and GV 4.8 ring and pinion with a 1510 Sierra Lockright.
No weird noises or problems as yet and its been fitted for3 years and 20,000kms so far.
You just have to make sure you use matching R&P. and everything is in good order. (not worn out)
