It is currently Sat Oct 31, 2026 6:54 am
Post Posted: Thu Dec 29, 2011 11:30 pm
hello. i have a suzi sierra and love it to bits but i also love my mates and would like to put seats in the back so we can all expirience the fun. I have been told they came out with seats so its just a matter of finding some.
so i thought i would ask around. so if you got any contacts or got one yourself let me know. thank you very much when i get a camera ill put good photos up so people on here can look at my white weapon
Post Posted: Fri Dec 30, 2011 12:31 am
you need to check the vin plate if its says 2 seater or 4 seater and than go from there
Post Posted: Fri Dec 30, 2011 9:07 am
Actually, the first SJ40's did not come out with rear seats. There was local demand for them, and they were a dealer fitted option. The seat itself was a locally manufactured item (by a company the usually made 3rd row seats for station wagons, etc) with "Hardware shop" bolts through the floor. As they also weren't factory fitted for rear seatbelts, part of the dealer installation was a filthy big stainless steel washer and bolt on the outside of the rear pillar (on hardtops, soft-tops weren't fitted with lap-sash belts, just lap belts).
Type 2 SJ40 (metal dash with 4wd light) was the first to offer rear seats, but only in JX trim, while Type 3 had them in all models (except traytop ute, of course!) JX had Split rear seats. JA had a Bench seat. Hard tops were cloth, soft-tops were vinyl.
Floor bolt pattern is different between Type 2 and Type 3 seats.
Post Posted: Thu Feb 13, 2014 6:52 pm
Is it possible to identify which type (1,2 or 3) an sj40 is just from the outside. Without looking at the dash or crawling under it. I guess I am asking if it is possible just from an external picture.
Post Posted: Thu Feb 13, 2014 9:53 pm
Type 1 has no plastic flares I'm pretty sure.
And type 2 & 3 are very similar except from the dash.
But you should be able to see the dash normally from a side on picture.
It's got the same dash as the 1.3 NT.
Type 3 has the plastic dash
Post Posted: Sat Feb 15, 2014 12:12 am
Type 1 had completely smooth rear door, T2 and T3 had large rectangular dimple in lower half.
Type 1 never had factory FWH, just a drive flange, although AVM hubs were a dealer-fitted option.
After 33 years though, anything could have been swapped around making originality hard to determine.
Post Posted: Sat Feb 15, 2014 1:09 pm
Trying to put up the picture I have.
Post Posted: Sat Feb 15, 2014 1:11 pm
Its only the type 3 thats gearbox will except the five speed internals, is that correct ?
Users browsing this forum: No registered users and 418 guests
