It is currently Thu Oct 29, 2026 2:08 pm
Vehicle: 89 Sierra Widetrack
Post Posted: Fri Mar 07, 2014 5:37 pm
Hi All,
My last two external fuel pumps have seized on my sierra with a g16b conversion.
First thing they where both from other cars (vl commodore) so it could just be bad luck and the pumps where old.
Currently I'm just running fuel tank > external fuel pump > fuel filter > engine > return line
Am I missing something? Do I need a lift pump?
I'm looking for a coily tank but the ones I found are out of my price range so for now I just need it running.
Anyone have any tips.. Will buy a new one when I have the funds.
Aaron
Vehicle: Suzuki Jimny 2010
Post Posted: Fri Mar 07, 2014 5:56 pm
I'd be running a fuel filter between the tank and the pump to stop any crap getting in the pump. Also leave the one between the pump and the engine as a little more security. I reckon there may have been a bit of crap got into the pump and stuffed it
Vehicle: sj51
Post Posted: Fri Mar 07, 2014 6:50 pm
im reasonably sure that vl's ran a scavenge pump in the tank to supply the external pump as the struggle with drawing up the fuel causing premature failure
i could well be wrong tho
Vehicle: Sj51t
Post Posted: Fri Mar 07, 2014 7:01 pm
your right pez all rb30 vls run a intake then a external pump
Vehicle: 91 sierra, g16b,lift,30's
Post Posted: Fri Mar 07, 2014 8:58 pm
In my g16b sierra. I had tank to filter to lift pump to Vl turbo pump to surge tank tohigh pressure filter to injector rail then I upgraded the return line and feed line.
I never had my Vl pump fail. However my lift pump failed once I think cause it had no prefilter which is I why I then run a prefilter
Post Posted: Fri Mar 07, 2014 8:59 pm
Should if said to surge tank than Vl pump
Post Posted: Sat Mar 08, 2014 12:22 am
How much crap in your tank? I reckon a scale of rust or something has seized them up. If the pump is mounted near the tank and is not ridiculously high, it should have no problems priming and working correctly whilst having a long life. A large low pressure fuel filter before the pump would be a good idea. Last time I got a new pump it was only $40 from repco.
Post Posted: Sat Mar 08, 2014 9:07 am
Thanks for the responses guys. Might run a lp filter before the fuel pump this time. Basically the fuel pump is mounted where the original sierra fuel filter was.
Not sure what condition the inside of the tank is like. I might try and pull the tank out.
I was quoted $160 for a new external fuel pump from Repco. Which pump did you use?
Post Posted: Sat Mar 08, 2014 10:49 am
Just some generic brand inline pump for a VL. Maybe they bumped the prices back up..
Post Posted: Sun Mar 09, 2014 6:28 am
Get a cheapy off eBay.
Vehicle: Sj51t
Post Posted: Sun Mar 09, 2014 10:07 pm
I have few Vl pumps intake and out tank ones from my Vl turbo days
Users browsing this forum: No registered users and 355 guests
