It is currently Wed Oct 28, 2026 9:08 pm
Post Posted: Fri Mar 14, 2014 8:02 pm
Hey guys, i want to install a fuel cell into the rear of the vitara for a few reasons but i am not sure how to go about it.
I can purchase the fuel cell and mount it easy enough, however what sort or capacity fuel pump do i need and is there anything special required for running the wiring etc.
Main reason is the move the fuel tank out of harms way, save weight and have more room under the car for suspension mods.
Post Posted: Fri Mar 14, 2014 9:08 pm
What suspension mods are you doing?
Where are you going to move the fuel cell to?
Can you make the stock vitara fuel pump fit into the tank?
Can you use the stock vitara wiring etc?
Post Posted: Mon Mar 17, 2014 2:25 pm
If you asked me really nicely brad I could answer all your questions but its gonna cost you a 6 pack ha
Post Posted: Mon Mar 17, 2014 7:14 pm
Will the stock tank fit between ur cage?
Post Posted: Mon Mar 17, 2014 9:18 pm
The power output of your N/A 2.5L is nothing special hence you would be hard pressed finding a HP fuel pump that could not keep up-to demand. Nothing very special about the pump wiring either. All pumps have 2 wires with you can simply patch into to your existing vitara harness.
Post Posted: Tue Mar 18, 2014 9:30 am
Thanks guys I have a good idea about where to go now. Will update when its getting built.
Users browsing this forum: No registered users and 332 guests
