It is currently Thu Oct 29, 2026 12:22 am
Vehicle: Drover pickup turk
Post Posted: Tue Mar 18, 2014 11:11 am
Quick question, Trying to find a spot to mount my power steering res and found it will work best where the overflow bottle is. Can I mount the overflow bottle down low or will that effect coolant getting back into the radiator?
I'll grab a pic in a moment to show where I want to mount it.
I like the tuna here
Post Posted: Tue Mar 18, 2014 11:54 am
Post Posted: Tue Mar 18, 2014 12:25 pm
It works on suction so it doesn't really matter where it's mounted
Vehicle: 85 ' Drover
Post Posted: Tue Mar 18, 2014 12:56 pm
Yer as far as i understand as long as its a sealed line and the end of it is submerged in water in the overflow bottle then its all good.
About the only real design issue to consider is that you can easily see the level in it.
Post Posted: Tue Mar 18, 2014 1:00 pm
What HID's are you using in the spotlights? How do they seal in the back of the light?
Post Posted: Tue Mar 18, 2014 1:41 pm
Some generic eBay ones, Round grommet in a square hole. :roll:
I can grab a pic if you like?
Post Posted: Tue Mar 18, 2014 3:33 pm
Na, that's cool. Sounds like the ones I stuck in mine (same lights)
Vehicle: 92 wt soft top sierra
Post Posted: Tue Mar 18, 2014 7:05 pm
Is that cooler on the front of your radiator for the powersteer
if so where did you get it
Cheers Marvin
Post Posted: Tue Mar 18, 2014 7:09 pm
Sure is.
eBay, PWR brand.
Post Posted: Tue Mar 18, 2014 7:12 pm
Awesome thanks for that did you find you needed it or just as a precaution.
Post Posted: Tue Mar 18, 2014 7:28 pm
Just a precaution. I'm still setting up for power steering so I figured why not.
I grabbed the big one in the event I can later use it to cool an auto and get a smaller one for the power steering.
Post Posted: Tue Mar 18, 2014 7:40 pm
Another option for a ps cooler is an 'engine oil cooler' off a corolla. Many have them. Clean them out and Bobs your Aunty
Post Posted: Tue Mar 18, 2014 7:47 pm
Thats not a bad idea thanks for that
Cheers Marvin
Users browsing this forum: Google [Bot] and 605 guests
