It is currently Wed Oct 28, 2026 7:24 pm
Vehicle: 2004 GV sport v6
Post Posted: Sat Mar 22, 2014 12:46 pm
Hey guys, all the info I read on this site tells me that my 2004 auto sq625 GV has an alloy front diff, however when i use a magnet to test if it's alloy or steel it sticks the the entire diff housing making me think it is steel. Can anyone help me out by telling me if the 2004 GV sport auto 2.5 has steel or alloy front diff.
Post Posted: Sat Mar 22, 2014 4:01 pm
At some stage Suzuki did put steel diffs in the autos. I think it was when they did the interior update in late 2003.
But they also did a complete design swap at some point. Take a pic of your diff and show us as much detail as possible. it will help us determine if your diff is able to take a locker or clarify when the change took place
Post Posted: Sat Mar 22, 2014 4:11 pm
I'll take some pics tomorrow as the missus has the car at work. It is an 04 and it does have the new interior.
Also does anyone know if an arb air locker fits my rear diff
Post Posted: Sat Mar 22, 2014 11:00 pm
Yep 12 bolt arb locker from a vit will fit the rear same axles as well.
Post Posted: Mon Mar 24, 2014 10:17 am
Cheers for all the info fellas I'll take some pics and put them up this arvo
Vehicle: 99 Grand Vitara
Post Posted: Mon Mar 24, 2014 12:53 pm
I'm 99% sure it would be a steel diff being an 04 and you said the magnet stuck to it.
http://www.strictly4x4.com.au
Post Posted: Mon Mar 24, 2014 3:30 pm
here we go boys, sorry about the crap photos.
Rear Diff
front diff
and a cheeky one of the new ride
Post Posted: Mon Mar 24, 2014 3:40 pm
the rust on it would seem to indicate its steel, wouldnt it?
Post Posted: Mon Mar 24, 2014 4:13 pm
Yeah thats what i would have thought as well as the fact that the magnet sticks to it. But just wanted to confirm it. Also wanted to know which rear diff i have and if an arb air locker will fit the rear diff
Post Posted: Mon Mar 24, 2014 5:16 pm
You'll have a 12 bolt rear diff. You'll need to pick up a vitara rear diff housing and put your ring and pinion into it along with an RD209 locker.
Fronts definitely a steel diff.
Post Posted: Mon Mar 24, 2014 8:11 pm
So I've found conflicting info online, do I need a vitara rear third to fit an arb locker to the rear diff?
Post Posted: Mon Mar 24, 2014 8:24 pm
Yep, that's all you need. Pretty sure all the internals bolt up to each other. Will you be changing your diff ratios or staying stock? If you're changing make sure you get the 12 bolt R&P.
Post Posted: Mon Mar 24, 2014 9:28 pm
Staying stock as only going to 225 75 r16
Users browsing this forum: Google [Bot] and 324 guests
