It is currently Mon Nov 02, 2026 8:06 am
Post new topic Reply to topic  [ 121 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Vehicle: Suzuki Jimny 2010
Post Posted: Tue Feb 11, 2014 12:38 pm
macguyverjimny wrote:
Im having trouble to source a auto vvt,
So i am investigating if i cant buy the different parts from suzuki and perhaps change my vvt transfer to an auto one.
After some research on parts catalogues, it seems that there are only about two or three parts that would needs replacing, namely a chain an input gear and output gear, so in othe words the chain and both sprocket gears , but i am first investigating,
So thank you guys, if anyone have experience on an auto vvt and know if its planatary gears for lowrange or helical please let me know :)
Thanx for an awesome thread Shep, alot of good info here,
http://bit.ly/1fbjHJN
Hit these guys up... They'll have one.
I paid about $395+ postage.
Vehicle: 91 Tin Top
Post Posted: Tue Mar 25, 2014 9:04 am
Sounds like this is a pretty common upgrade these days with good results for those on bigger rubber.
I know all the guys running 30s are happy with this set up, but would be interested to hear if anyone is running smaller tyres with these gears and what the highway revs are like.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Mar 25, 2014 9:34 am
it would be doing over 4200rpm with 235/75 15s for sure
Vehicle: 2008 Jimny Standard As :-)
Post Posted: Tue Mar 25, 2014 9:39 am
mine was doing close to that on the highway with 30's
Post Posted: Tue Mar 25, 2014 10:12 am
From my gear calcultator
Figures used, in case they are incorrect
m13a vvt manual
5th gear 1:1
diff gear 4.3:1
vvt auto transfer 1.32:1
With a true 235/75R15 (28.8") for diameter it will be 4102rpm at 100 km/h
Based on true diameters
28" tyre = 4234 rpm
29" tyre = 4088 rpm
30" tyre = 3951 rpm
31" tyre = 3824 rpm
NOTE: True diameters can be pretty far out form the manufacturers designations and manufacturers claims.
Vehicle: 91 Tin Top
Post Posted: Tue Mar 25, 2014 10:17 am
^^^ Excellent, thanks mate.
Vehicle: 2006 Z Series Jimny
Post Posted: Tue Mar 25, 2014 10:46 am
With Deestone 235/75R15 muddies and quite a bit of extra weight like bullbar, sliders, bash plates, tools, tirfor and myself :) I'm sitting on a tad over 4100 rpm at 100 KPH. Speedo could still be a little out though wouldn't be much judging by the other traffic.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Mar 25, 2014 11:48 am
shep and i on 30's both got the same result, 4150rpm @ 100kph gps. dont see how a 235/75 r15 can be turning slower being smaller diameter. his is new and mine is 2010
Post Posted: Tue Mar 25, 2014 12:57 pm
Unless the gear ratio, diff ratio or vvt auto xfer case ratios are wrong (which was why I showed which numbers I used).
We need to consider the errors involved which can be significant when trying to be exact with the numbers.
For example
Speedo reading error... the difference between 100km/h and 103/km/h on a 30" tyre is 119 rpm ( a couple of km/h is hard to accurately spot on a needle)
Tacho errors - they are not really accurate, let alone the eye seeing them for a precise figure (unless you are using an IR laser tacho etc).
and as I mentioned before...
True tyre sizes!
These are not consistent, different sizes, different manufacturers etc means these results will never correlate exactly to others.
There are tolerances in the speedo calibration and manufacturers ensure the speedos generally over-read the true speed by up to 10%. i.e showing 100 km/h on the speedo, when the camry driver is doing 90km/h and driving those with GPS crazy.
Changing brands of tyres which are the same size can affect the speedo, just like air pressure etc by the ADR forcing manufacturers to ensure the speedo over reads (and the operator is responsible for ensuring the speedo is ADR compliant) removes all wriggle room for people to challenge speeding fines.
Simply for these purposes an approximation is good enough, as the only exact known is the gear ratios.
Don't get too lost in the exactness
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue Mar 25, 2014 1:41 pm
in short we need 1 car, a gps speedo, a Bluetooth rpm reader to accurately read the rpm to as many decimals as we can, and a shitload of tyres and rims at multiple pressures, brands, and sizes and tread paterns.
anyone board?
Post Posted: Tue Mar 25, 2014 4:18 pm
GPS speed?
Post Posted: Tue Mar 25, 2014 5:06 pm
My speedo is 101-102 for a GPS 100kph
Post Posted: Tue Mar 25, 2014 5:11 pm
wow really, mine was 100 GPS for 109/110 Speedo
Post Posted: Tue Mar 25, 2014 9:30 pm
Mines near bang on 100 for 100. Maybe a smidge toward 101 on the speedo
Post Posted: Tue Mar 25, 2014 9:31 pm
And at 4150
Post Posted: Wed Mar 26, 2014 5:40 am
100 GPS for 108 Speedo for me
Post Posted: Wed Mar 26, 2014 6:20 am
Do you have late model jimnys with a auto transfer for gearing reduction?
Post Posted: Wed Mar 26, 2014 6:23 am
I have a 2008 Model Manual VVT NS Have/had a Auto Transfer of the same year.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Mar 26, 2014 7:16 am
now this is interesting. 2010 jimny, 2010 vvtauto tcase, 100@100gps +/- 1kph.
i want to find a set of 235's that are the same height (diameter) as a bfgKM2 muddy. in my mind a 28" tyre should never be 30", but if there out ther id like to know. should providebetter fuel economy and give the height at the diffs i want. other option is those trailer tyres shep has, 700something... but they also didnt look very sticky
Post Posted: Wed Mar 26, 2014 12:22 pm
The size is 750r15. I don't thing a radial tyre in that size is available
Post Posted: Wed Mar 26, 2014 4:51 pm
Me?
No, but what difference would it make? Speed is read from rear output of the transfer, so as long as we have the same diff ratios and both have 30s the reading should be the same.
Post Posted: Wed Mar 26, 2014 6:52 pm
It isn't the same, that's my point. My speedo under read by about 15% with stock gearing and 30" tyres but now it is pretty much spot on.
Post Posted: Wed Mar 26, 2014 7:03 pm
Yeah there's something with the readings... Mine was out by 6% with my trial jimny gears but the odometer was out 11%. Now being spot on, the odometer is still out 3%. The only way I can see this happening would be there being two sensors right? I can't say I've seen any others???
Post Posted: Wed Mar 26, 2014 8:26 pm
Where with my 08 Jim and 30's with the stock case i'm about dead on 100@100
Post Posted: Wed Mar 26, 2014 8:48 pm
So digital speedos are a bit all over the shop. Maybe facelift Jimny has some difference with the speedo.
Post Posted: Wed Mar 26, 2014 8:50 pm
There was a difference in the way my two Jimny speedos have worked. Different models.
Vehicle: 91 Tin Top
Post Posted: Thu Mar 27, 2014 7:16 am
Cheers guys.
I was more interested in the RPM at highway speeds in manuals with auto transfers running tyres under 30 inch.
I'm thinking about gearing, but not looking to go massive tyres. Will most likely go with something like Mr Nutter, but not for a while longer it think. All the good camping spots are at least 2-3hrs of highway driving and I couldn't do 4200+ rpm for that long...
As for speedos, they are most def all over the place, mine at stock was 5k's out to the gps, running 215s it's spot on...
Post Posted: Thu Mar 27, 2014 12:40 pm
I recently did a 9000km trip and cruised between 4500-5000rpm and the car loved it.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Mar 27, 2014 1:53 pm
holey shit, that's through testing
Post Posted: Thu Mar 27, 2014 7:26 pm
Was towing my camper as well. Cruised at 110-120kph.
Users browsing this forum: No registered users and 60 guests
