It is currently Fri Oct 30, 2026 10:49 am
Vehicle: Suzuki
Post Posted: Sun Apr 06, 2014 7:02 pm
I have done a search but can't find any details, is there a 'how to' guide for converting auto hubs to manual locking hubs?
Vehicle: Suzuki Jimny 2010
Post Posted: Sun Apr 06, 2014 7:15 pm
What vehicle are you fitting them to mate?
Post Posted: Sun Apr 06, 2014 8:07 pm
SV420
Post Posted: Sun Apr 06, 2014 8:08 pm
No idea then hahaha
Post Posted: Sun Apr 06, 2014 11:05 pm
Unbolt the auto, slide off, slide on manual, bolt on - test drive.
Post Posted: Sun Apr 06, 2014 11:19 pm
It really is that simple - it's probably why you're not finding a guide - it's really not necessary.
Six bolts hold the auto hub on, remove them, slide the hub off, and then follow the instructions that came with your manual hubs, which will go along the lines of - grease the paper washer and install, slide the hub base on and bolt down with the six bolts from the auto hub, install a second greased paper washer, and add the hub cap and secure with six allen screws,
Vehicle: 2004GV + bar + custom mods
Post Posted: Mon Apr 07, 2014 9:58 am
Here's some info from my build; http://auszookers.com/forum/viewtopic.p ... 2&start=60
It's pretty much as Fordem said.
Use a torque wrench to tighten these bolts. Make sure they come with cone washers, or get ready to lock them a different way.
Vehicle: Suzuki
Post Posted: Mon Apr 07, 2014 6:52 pm
Are these the cone washers you are talking about?
Vehicle: Suzuki
Post Posted: Mon Apr 07, 2014 6:53 pm
What about the vacuum lines? Do I need to block them off?
Post Posted: Mon Apr 07, 2014 10:35 pm
1 - Whether or not cone washers are required will depend on the particular free wheel hubs used - OE Aisins use them, as far as I know none of the after market hubs do.
2 - What vacuum lines? As far as I know, the auto hubs on the SV series are not vacuum operated.
Vehicle: Suzuki
Post Posted: Tue Apr 08, 2014 8:11 am
I just assumed that they were vacuum operated, that makes the change over easy!
Now I just need to order the paper gaskets, I guess I just get these from Suzuki?
Post Posted: Tue Apr 08, 2014 9:53 am
That's right.
Yeah cone washers come with the AISIN or stock vitara hubs. AFAIK they help keep the hub bolted in without thread lock.
As for gaskets, you can order them (I think suzistore has them) or cut them yourself like I did. Not hard, just need to buy some gasket material, trace the holes and then do a bit of exacto knife work.
Vehicle: 92 WT Sierra
Post Posted: Tue Apr 08, 2014 10:06 am
Hubs of an SE Vitara will bolt straight on they are what is currently on my SV420. I also changed over to bolts with allen key heads. Makes it slightly easier to take the hubs off instead of trying to get a socket over the hex heads.
Users browsing this forum: Google [Bot] and 327 guests
