It is currently Fri Oct 30, 2026 9:58 am
Vehicle: 98 Jimny
Post Posted: Thu Apr 10, 2014 8:38 am
Hi everyone i'm planning to run some 32" on my jimny and need to upgrade my front axle and CV's (it has a front locker)
1.Is it true that if you change the 26 spline Axle and CV' your diff pinion and king crown get shatter because they cant handle the extra pressure??
2.If i got the 22 spline Axel and CV from http://www.piranhaoffroad.com.au/produc ... zuki-jimny would that be able to handle the 32"??
3.Would it be a better option to just get a chrome molly 22 spline axle and just put the shrink ring over the normal CV?
4.Does anybody know anyone thats done any of these upgrades that i could talk to or could you send me the link of a thread which may help me?
Post Posted: Thu Apr 10, 2014 8:47 am
1. no, no reason your diff will explode just because you have chromos
2. are you talking about the $2000 upgrade cvs? why would you do that, i dont see any poiint in buying 22 spline axles when 26 spline are available
3, no, birfield rings went out with the invention of chromo cvs
4. im sure wilso will be along soon, he runs chromos and bigg rubber on his jimny
Vehicle: 98 Jimny
Post Posted: Thu Apr 10, 2014 8:58 am
Thanks Tanshi are you still getting those 26 spline axle and CV's made up??
Post Posted: Thu Apr 10, 2014 9:07 am
I will be yes, there are some delays unfortunatly,
Vehicle: Suzuki Jimny 2010
Post Posted: Fri Apr 11, 2014 10:51 pm
Don't bother with 22splines... You will break them eventually. Wilso and I have broken them on 30's
Axles not cvs ^^^
Post Posted: Fri Apr 11, 2014 11:24 pm
^yeah sadly my first set I had made failed.
32 aye, good luck keeping it low, im running H/T 31" tyres with 40mm of lift 45mm bumpstop spacers and it still rubs allot even after ive (with a grinder and a welder) chopped large sections out of my guards. I fear to fit my new 31s ill have to run larger bump stop spacers. Or gain some height, but I am 3-linked too so that probably has allot to do with it.
As for axle upgrade, go 26spline, and you will need to twist some of the right peoples arms to find you a set of sierra chromoly CVs separate from the axles as TT and LROR don't separately sell the axles. Or buy a complete sierra chromo set and make new axles for it.
Also, not sure if internet legend or not, but the way jimny front diffs are cut when driving forward they are pulling into each other giving a sweet contact patch, when it reverse they try to push apart and would be significantly weaker. Ive had my diff apart enough to see the ring flex bolt has good scrub marks on it so its flexing 2-3mm to touch it.
So, if you have the cash and time for this, also purchase an RD208 airlocker and put it in the front too. For an ARB locker, plus axles and CVs, I wouldn't expect to see much change from 2.5K.
Or just weld up some rear sierra side gears and hope your power steering holds up lol
Post Posted: Sat Apr 12, 2014 9:06 am
Wind your load bolt in 1.9-2.9mm josh!
Post Posted: Sat Apr 12, 2014 9:44 am
^do you know what it actually should be? I thought about a 1-2mm gap would be about right due to bearing/steel flex
Vehicle: 98 Jimny
Post Posted: Sat Apr 12, 2014 10:19 am
Ill be getting a ARB airlocker in the front, what is a RD208 is that a sierra front locker or just the code for the jimny ??
well i have done a far bit of cutting of my guards have a 4" ORA lift, 2" body lift and if that doesn't do it ill add some spring spacers and ill be trimming my ARB front bar as well so hopefully that should do the trick. (yes i know sounds like a death wish)
probably sounds dumb but do you know anyone who makes or sell 26 spline side gears??
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sat Apr 12, 2014 10:50 am
Im holding off on lockers waiting to see what jml bring to the market
Post Posted: Sat Apr 12, 2014 11:15 am
RD208 is the jimny rear locker that should fit the front. I have an RD207 with 26spline sidegears.
Post Posted: Sat Apr 12, 2014 12:25 pm
Isn't the front housing smaller?
Post Posted: Sat Apr 12, 2014 12:31 pm
More like .1
My Vit one has .2
Post Posted: Sat Apr 12, 2014 1:21 pm
Rd206 and rd207 are jimny front lockers. As far as I know Rd208 won't fit the smaller housing/third member.
Post Posted: Sat Apr 12, 2014 2:36 pm
Yeah it is a smaller center, but the internals are the same cause the 26spline kit fits.
So to run 26spline axles jimnys need RD207 lockers and then buy a 26spline kit.
If joe knows the actual sizes he can chime in anytime he likes :P
Vehicle: 98 Jimny
Post Posted: Mon Apr 14, 2014 9:22 am
whats the difference between running the front locker with 26 spline axles compared to running rear locker in the front with 26 spline axles??
(sorry didnt know you could run the rear in the front)
Users browsing this forum: Google [Bot] and 281 guests
