It is currently Wed Oct 21, 2026 11:33 am
Vehicle: WR250F/Jeep XJ
Post Posted: Mon Aug 24, 2009 2:43 am
I need to find a motor of a small size with the ability to rotate rather than push/pull (like an air ram) and it needs to complete this task up to 1.47nm (15kgf/cm) at a rough guess. The starting torque would probably need to be pretty high as well i.e. the motor can't "spool up" to reach this torque level, has to be instant/on demand.
Anyone got any ideas? It's for a secret squirrel mod I have in mind. :cheers:
Something similar to this...Brushless electric motor
I'm guessing local supply might include Jaycar? Anyone know anywhere else I can find one?
Post Posted: Mon Aug 24, 2009 3:00 am
It`s a Dongling!!
Jay car, was in a brisy store yesterday & saw similar.
Steve
Post Posted: Mon Aug 24, 2009 3:01 am
if u go to jaycar try part numbers
yg2732 12V, 2.1kg/cm Torque
This compact unit will give a massive 2.1 kg/cm of torque at 70 RPM. Current draw rises to a modest 390 MA.
SPECS:
• Torque: 2.1kg/cm
• Rated Voltage: 12.0V
• Operating: 4.5 - 18V max
• Current - No load: 30mA
• Current - Full load: 390mA
• Gear Ratio: 82:1
• Shaft Speed: 70RPM
yg2734 Only slightly larger than the YG-2732, but with a massive increase in torque at 36RPM. Ideal for driving wheels or other traction devices.
SPECS:
• Torque: 12.0kg/cm
• Current - No load: 70mA
• Current - Full load: 1380mA
• Gear Ratio: 244:1
• Shaft Speed: 36RPM
yg2738 12V DC Reversible Gearhead Motors - 160RPM
As part of our new mechatronics range, we are proud to introduce 3 combined miniature motor/gearbox sets. The motors work equally well in forward or reverse motion.
For heavy duty applications.
- Massive 50kgs torque at 55RPM
Torque: 50kg/cm @ 55RPM
Operating: 6 -12Vmax
Current - No Load: <450mA
Current - Full Load: 14A
Gear Ratio: 50:1
Shaft Speed: 160RPM
Weight: 0.32kg
if u go onto the jaycar website u can see the full specs on them
www.jaycar.com.au
333...................im only half evil
Post Posted: Mon Aug 24, 2009 3:04 am
steknig wrote:
It`s a Dongling!!
Steve
:rofl: not quite a dongling but it will defintely give my 4wd passenger some pleasure hahahahaha....stay tuned for the build....
Thanks DJ, stall torque is ~7 times what I want on that 3rd one you listed...it should do the job even though its geared....wanted to stay away from geared for reliability but this one may have enough fudge factor for it to work ok.
Vehicle: LJ20 LJ50
Post Posted: Mon Aug 24, 2009 10:16 pm
Use an Air drill, or a cheap arse air die grinder. Air motors have no real torque without gearing
Camels have nice toes
Users browsing this forum: No registered users and 115 guests
