It is currently Fri Oct 30, 2026 6:53 am
Vehicle: 1996 Vitara
Post Posted: Thu Apr 24, 2014 12:30 pm
G'day all, I recently picked up a 1996 Vitara and now need to buy a cheap obd2 tool off eBay to diagnose a check light error. Can anyone point me in the right direction on which one to grab, a link would be great.
And first post fella's expect plenty of more questions to come....
Cheers Rich
Post Posted: Fri Apr 25, 2014 8:33 pm
Cheapest way is to bridge a couple of the pins in the diagnostic plug, then when you turn the car on the CEL will flash a sequence at you. Count the flashes and that'll tell you what the error is.
Have a read: http://www.rhinopower.org/diag/cel.html
Post Posted: Fri Apr 25, 2014 10:12 pm
A 96 Vitara will not be OBD2 compliant, you're limited to the jumper method mentioned above, the dealer OBD tools, or an interface & software from Rhinopower.
Post Posted: Tue Apr 29, 2014 7:46 pm
Thanks for the replies. I'll have a crack at the rhinopower procedure tomorrow.
Cheers Rich
Post Posted: Wed Apr 30, 2014 1:08 pm
Thanks for the rhinopower link. It was the Oxygen sensor, I reckon it's socket wasn't full pushed home after the body lift.
Cheers Rich
Post Posted: Sun May 04, 2014 8:07 pm
They do have a habit of dying. Abiut $80 for a replacement if necessary.
Users browsing this forum: Google [Bot] and 320 guests
