| Author |
Message |
Dan85
Joined: Mon Sep 10, 2012 8:43 pm Posts: 389 Location: laurieton
Vehicle: 2012 jimny
 Posted: Fri May 02, 2014 2:12 pm |
Hi everyone. Just trying to install the 50mm efs kit i just received and im having trouble getting the front springs out. The problem im having is the smallest spring compressor i can find seems to big and doesn't fully grab the springs so i cant get them out. any ideas how to do it or do i just have to go find some smaller spring compressors?
Jezza86
Platinum Supporter
Joined: Tue Dec 06, 2011 9:30 am Posts: 2155 Location: Nhulunbuy 0880
Vehicle: 2010 jimny
 Posted: Fri May 02, 2014 2:50 pm |
undo the bottom of the shocks, jack the chassis till the spring falls out watch out for you vacuum hoses and breaklines.
pete_79
Vehicle: 91 Tin Top
 Posted: Fri May 02, 2014 3:28 pm |
Dan85
Vehicle: 2012 jimny
 Posted: Fri May 02, 2014 10:57 pm |
thanks guys. got it working. I got the front in but the back is still stock so it looks like a gangsta caddy with a lowered rear end.
sur5a
Joined: Sun Aug 25, 2013 7:14 pm Posts: 181 Location: W.A.
Vehicle: 2013 JImny
 Posted: Fri May 02, 2014 11:16 pm |
Hey Dan if you need a hand,give us a yell ,I'm not far from you
Dan85
Vehicle: 2012 jimny
 Posted: Fri May 02, 2014 11:27 pm |
The fronts done but your welcome to come help with the rear and have a beer or three. My panhards arrived today so contemplating putting them in as well.
sur5a
Vehicle: 2013 JImny
 Posted: Fri May 02, 2014 11:40 pm |
no worries,I'm pretty much free tomorrow
Dan85
Vehicle: 2012 jimny
 Posted: Sat May 03, 2014 1:52 am |
Sounds good I'll pa you address and phone number. Got an appointment at 1030 so anytime after 11 is good with me.
Dan85
Vehicle: 2012 jimny
 Posted: Sat May 03, 2014 5:07 pm |
big thanks to Dave for coming and giving me a hand it was alot easier with two!! we encountered a problem tho. the passenger side rear shock wont line up with the mount. we tried various iterations of jacking it up at various spots and it still wouldnt go. now i think ive fucked the bolt and thread a little. so ive got a few ideas:
1. mount the bottom of the shock first and then the top mount after. 2. get shock relocation brackets.
as far as the stuffed thread am i better off just drilling the mount out and using a bolt and nut?
jimny_timmy
Vehicle: Suzuki Jimny 2010
 Posted: Sat May 03, 2014 7:58 pm |
Both Wilso and I have drilled our bottom mounts out after the thread stripped. Being a really fine thread (1.25) they strip quite easily and also have issues with undoing themselves. I've even had them come out with loctite. Get a 12mm x 150mm bolt with a nylock but and you'll be trouble free.
And make sure you use loctite on all your shock bolts... They will come undone lol
zukenutter
Joined: Sun Feb 08, 2009 10:30 pm Posts: 9045 Location: Brisneyland
 Posted: Sat May 03, 2014 8:39 pm |
Shock mount relocators are worth adding. The axle rotates when you raise the rear, this puts a twisting force on the shocks.
_________________ Click WWW below for STICKERS
Dan85
Vehicle: 2012 jimny
 Posted: Sun May 04, 2014 7:13 pm |
Thanks guys. I drilled the left mount out and it was a piece of piss. I'll do the right one once the re locators arrive.
pete_79
Vehicle: 91 Tin Top
 Posted: Mon May 05, 2014 7:16 am |
I also used the nuts off the stock front shocks as locking nuts on top of the new front shocks.
Dan85
Vehicle: 2012 jimny
 Posted: Mon May 05, 2014 8:46 pm |
Pete unfortunately my nuts had to be cut off otherwise I'd do that. I might go buy some more and do it anyway. Good idea
