| Author |
Message |
Chris_Staff
Vehicle: Suzuki Jimny 2004
 Posted: Mon Jun 02, 2014 11:18 am |
Hey I was after some sunraysia or sunraysia style rims for my jimny and was just wondering what companies sell them here in Australia?? and how much they cost on average ? Cheers
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5946 Location: Northcliffe, W.A.
 Posted: Mon Jun 02, 2014 11:41 am |
Any tyre shop will be able to get them. Typically, you ask for F100 wheels. There's to many brands, sizes, offsets, styles and so on to list.
Buying new steel wheels you should expect to pay between $60 and $100 each depending on what you want. My white 15x7s were $62 each from tyrepower, I think they're CSAs.
Sanraysia closed down years ago, their name just carries on to that style of wheels.
Chris_Staff
 Posted: Tue Jun 03, 2014 3:44 pm |
Oh really didn't know that, so is the F100 the same stud pattern as the Jimny?
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Wed Jun 04, 2014 7:12 pm |
^yes.
Can't be 15x7 -neg0 or it will rub on the steering arms. Neg13 will be sweet
Jezza86
Platinum Supporter
Joined: Tue Dec 06, 2011 9:30 am Posts: 2155 Location: Nhulunbuy 0880
Vehicle: 2010 jimny
 Posted: Wed Jun 04, 2014 7:43 pm |
Speedy do a neg 15 which is fine if you chop guards
Chris_Staff
 Posted: Fri Jun 06, 2014 11:06 am |
so if you go a F100 rim the 0 offset won't work??
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Fri Jun 06, 2014 12:04 pm |
I tried -6 15x7 rims on my jimny and they rubbed on the knuckle steering arm thingo. I settled on 16x7 sunnies with -15 offset. They fit great.
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
Chris_Staff
 Posted: Fri Jun 06, 2014 2:50 pm |
With the offset rims will I need to add flares?? I wanted to keep the same specs as the stock rim just want the different look.
Jezza86
Platinum Supporter
Vehicle: 2010 jimny
 Posted: Sat Jun 07, 2014 9:05 am |
with a correctly setup panhard, my 30x9.5's on the speedy desert rat 15x7 -15mm offset have the tread just inside the guards, and the side wall bulges just outside the guards, by 2mm or so...
31zook
 Posted: Sat Jun 07, 2014 4:07 pm |
Chris_Staff wrote: so if you go a F100 rim the 0 offset won't work?? Original F100 wheels are 15x8 -25 I think and yeah they fit
murcod
Joined: Thu Apr 16, 2009 11:30 pm Posts: 327 Location: Adelaide
Vehicle: XL-7 (gone) + Kizashi
 Posted: Sun Jun 08, 2014 1:47 pm |
Be careful what brand you buy. I bought some new CSA Ranger http://www.mullins.com.au/stw.asp sunraysia type wheels and A/T tyres for my old Feroza about 7 years ago. I had endless issues trying to get them balanced with horrendous steering wheel wobbles at various speeds. New tyres were fitted (after consulting the tyre company) with a similar result. The tyre shop then noticed sideways run out on the rims as they were trying to balance them. New rims were ordered, but they were exactly the same!? I ended up paying extra for alloys and it was fixed. There were also problems due to some brands cracking- details were circulating on various forums with pics from Aussie mining company vehicles IIRC. From the pin striping (red and blue) around the rim edge, they appeared to be the exact rims I had. Edit - found it http://mines.industry.qld.gov.au/assets ... ert211.pdfBottom line- they can be cheap and nasty. If you could find some OEM steel wheels they would probably be a lot better made.
Rhinoman
Joined: Mon May 16, 2011 7:03 pm Posts: 686 Location: Brinkworth, England
 Posted: Mon Jun 09, 2014 8:15 am |
That's a bit worrying. Do those types of rim usually have the pinstriping? over here its a characteristic of Weller Wheels but they tend to be quite robust as they were originally designed for rally cars.
murcod
 Posted: Mon Jun 09, 2014 12:33 pm |
Chris_Staff
 Posted: Tue Jun 10, 2014 2:38 pm |
murcod wrote: Be careful what brand you buy. I bought some new CSA Ranger http://www.mullins.com.au/stw.asp sunraysia type wheels and A/T tyres for my old Feroza about 7 years ago. I had endless issues trying to get them balanced with horrendous steering wheel wobbles at various speeds. New tyres were fitted (after consulting the tyre company) with a similar result. The tyre shop then noticed sideways run out on the rims as they were trying to balance them. New rims were ordered, but they were exactly the same!? I ended up paying extra for alloys and it was fixed. There were also problems due to some brands cracking- details were circulating on various forums with pics from Aussie mining company vehicles IIRC. From the pin striping (red and blue) around the rim edge, they appeared to be the exact rims I had. Edit - found it http://mines.industry.qld.gov.au/assets ... ert211.pdfBottom line- they can be cheap and nasty. If you could find some OEM steel wheels they would probably be a lot better made. Really? Shit didn't know about that... Do you know of any strong brands that don't break?
Chris_Staff
 Posted: Tue Jun 10, 2014 2:46 pm |
