It is currently Tue Oct 20, 2026 9:59 pm
Post Posted: Fri Aug 28, 2009 3:27 am
are coil spacers worth the money with standard sj80 springs or should i wait until i have lifted suspension first???
Post Posted: Fri Aug 28, 2009 3:58 am
coil spacers with longer struts would be okay, but with standard struts you will fuck the mounts and the shocks will top out.
Post Posted: Fri Aug 28, 2009 12:49 pm
ok thanks saam
what setup do you have???
and do you have diagrams for your barwork, i really like it and it would be great if i could copy
Vehicle: WR250F/Jeep XJ
Post Posted: Fri Aug 28, 2009 2:30 pm
How can a strut top out when you have effectively lengthened the distance for the strut to top out with a coil spacer? Don't you mean it will just bottom out quicker?
all you are doing is effectively raising your ride height. The suspension travel will still be the same with a standard strut it will just have a higher static position. A longer strut would be better as you could get some more droop out of it. A struts internal bumpstop is designed to take bottom out loads so it shouldn't be a problem to whack a spacer in...you will get get less droop as you have rasied it however high the spacer is.
Post Posted: Fri Aug 28, 2009 8:15 pm
He'll get less travel with a spacer as the springs will compress up before the bumpstop is hit.
Users browsing this forum: Google Adsense [Bot] and 222 guests
