It is currently Wed Oct 21, 2026 2:48 pm
Post Posted: Sat Aug 29, 2009 6:08 pm
i need to get a fuel sender unit for my 86 drover as its not workin, are any year sierra units the same ??
Post Posted: Sat Aug 29, 2009 8:11 pm
1.0 or 1.3 NT or WT all use the same sender but I have a feeling coily units may be different.
Post Posted: Sat Aug 29, 2009 9:43 pm
That would be something fu*#%^g different hey, coily with a different, usually dearer part!!!! Shits me to tears.
Post Posted: Sat Aug 29, 2009 9:48 pm
i should have a tank somewhere that is out of a 85 drover. i will try and find it and see if it is ok.
Post Posted: Sun Aug 30, 2009 7:17 pm
okay cheers il ring a couple of wreckers here too and see if i can get one. mines acting weird when you have a full tank it says its empty on the guage then when its about half full it reads correctly, well i think it does anyway, but you hit a bump and the needle drops down and then the needle goes back up again. I assume this is the sender unit playing up ??
Post Posted: Mon Aug 31, 2009 2:54 am
coily same same
Had a coily tank with leafy guage with vit pump..
Used to work perfecto, then it would show dead empty when full. Then when your going to run out (going by kms) it would come up to 1/4 sorta fast, then dissappear just as quick...fooking thing.
Now using vit sender in vit tank in a leafy guage
Perfecto!
Vehicle: '92 Sierra
Post Posted: Mon Aug 31, 2009 3:56 pm
Easy fix mate. Check out this post. http://www.pointnshoot.org/modules.php? ... cle&sid=59
Vehicle: 75 Cruiser
Post Posted: Mon Aug 31, 2009 4:18 pm
or my dodgy tech...
http://auszookers.com/index.php?name=Forums&file=viewtopic&t=4140&highlight=fuel+float+fix
Post Posted: Mon Aug 31, 2009 8:03 pm
cheers guys didnt realise it was a common problem should have done some more research 8O
Post Posted: Mon Aug 31, 2009 8:04 pm
Mine works fine, when it goes below 'E' the car stops :oops: :lol:
Vehicle: '92 Sierra
Post Posted: Mon Aug 31, 2009 9:07 pm
steve wrote:
Sorry Steve, didn't realise you'd done a post on it.
Vehicle: 75 Cruiser
Post Posted: Mon Aug 31, 2009 9:55 pm
not a problem! the more options and info in a thread the better :D
Users browsing this forum: Google [Bot] and 133 guests
