It is currently Mon Oct 26, 2026 1:01 am
Vehicle: Vitara 1993
Post Posted: Mon Jul 14, 2014 5:30 pm
I started my body lift with my vitara and front two screws snaped off into the chassis what do I do now ???? Please help
Post Posted: Mon Jul 14, 2014 5:42 pm
drill out the broken bolt & re-tap the thread.
Post Posted: Mon Jul 14, 2014 5:52 pm
Thanks is there any way of geting the bolt out
Post Posted: Mon Jul 14, 2014 5:56 pm
you can try an easy out, but i'm guessing the bolt was rusted in there & you'll probably only end up breaking an ezy-out in the bolt.
Post Posted: Mon Jul 14, 2014 7:13 pm
You won't get them out with an easy out. You'll break the easy out. They aren't designed for seized bolts.
Post Posted: Mon Jul 14, 2014 7:16 pm
Do you know what type of thread they would be
Vehicle: Suzuki Escudo 1991
Post Posted: Mon Jul 14, 2014 7:20 pm
I had this happen the other day. I just drilled out the bolts then drilled some one inch holes in the side of the chassis then put a nut on end of bolt. Works primo and doesn't weaken anything.
Post Posted: Mon Jul 14, 2014 8:41 pm
That's the reason I supply nuts with my kits. Captive nuts tend to cause issues. The thread will most likely be damaged by the time you get the bolt out so it's easier to drill it out with a 10 or 11mm drill bit
Post Posted: Tue Jul 15, 2014 8:51 am
Two one inch holes either side of the chassis doesn't weaken anything?
Post Posted: Tue Jul 15, 2014 11:49 am
In the side of the chassis right that the front beyond any suspension or engine mounts a 25mm hole would be fine from an engineering perspective. I would avoid this on the top or bottom of the chassis though
Post Posted: Tue Jul 15, 2014 12:20 pm
I wasn't suggesting it wasn't OK at the ends of the chassis, but it's nonsense to assert it doesn't weaken anything.
Post Posted: Tue Jul 15, 2014 12:32 pm
Armsup this guy knows.
Users browsing this forum: No registered users and 312 guests
