It is currently Sun Jul 26, 2026 8:17 am
Post Posted: Tue Sep 01, 2009 2:08 pm
Do i need to remove transfer to pull gearbox?
(new clutch time)
Don't worry, It's only a suzi...
http://www.auszo
Post Posted: Tue Sep 01, 2009 2:10 pm
nah just pull the jack shaft.
Post Posted: Tue Sep 01, 2009 2:12 pm
its on the edge of slightly too heavy with 1 person..
Post Posted: Tue Sep 01, 2009 2:16 pm
are you gay? i have no collar bones and i can still remove/replace a sierra trans case on my own. :roll:
Post Posted: Tue Sep 01, 2009 2:18 pm
It's a little awkward but even I can lift it by myself :lol:
I usually pull the front driveshaft as well as the jackshaft, as it gives you more room to maneuver the box out. Pull the gear lever before you start too. If you still have the stock exhaust there is a bracket on the top of the cat. converter which can be a pain to get off, but if you undo that and disconnect the exhaust at the manifold flange that will give you more room to move too.
A 2" bodylift makes it a million times easier in my experience.
Post Posted: Tue Sep 01, 2009 3:34 pm
And don't forget the wiring on the firewall!! It's a pain to do while balancing the box on your head :lol:
Post Posted: Tue Sep 01, 2009 3:37 pm
Good tip!
Also, I usually drain the box before I pull it out, but you could probably use one of those plugs to stop the oil coming out the back of the box. In any case you need to address that if you don't want to be covered in gear oil!!!
Post Posted: Tue Sep 01, 2009 3:51 pm
Are you gay? Cos u must be reading in the closet? He said he is removing the gearbox not transfer! :finger:
And are you swapping the box while the car is on the ground? no jacks etc? Sorta an awkward position..
Post Posted: Tue Sep 01, 2009 4:25 pm
that was just a slip up, i meant the g/box.
what is so hard about it, i doubt that it weighs 30kg.
it is a tight fit but that is it.
Post Posted: Tue Sep 01, 2009 4:34 pm
Maybe im just weak.. I havent done it for bout 2 yrs.. I was younger then.. Now im lifting heavy stuff everyday so it prob be easier.
Yes i am weak, but not gay.. Not that there is anything wrong with that.. :lol: :? :lol:
I am married to a malteser with bootay :wink:
Vehicle: '92 Sierra
Post Posted: Tue Sep 01, 2009 5:38 pm
Sorry bluesuzy but I've got to agree on the gay call. :P I'm no tank and I find pulling the gearbox out to be a piece of piss. I'd go one further on shep and say its more like 20-25kg. I suggest you pull yours out while taping it just so we can get some respect back for you. Better yet come round and do mine so i can see it for myself and possibly throw a new rear main seal in :P
Now for the tech. Try cutting a small v slot in the front of your rear gearbox mount. There is like web on the back of the gearbox that is a pain in the arse if you don't cut the v in.
Post Posted: Tue Sep 01, 2009 5:43 pm
fess up time.. i did fuck up and read it as trans case :oops: :lol:
ball had to help me get the bastard back in :roll:
Post Posted: Tue Sep 01, 2009 6:02 pm
Hey a V is a good idea. I just took about 10mm off the front of the bracket.
Post Posted: Tue Sep 01, 2009 6:09 pm
Buhahahaha silly Shep.
Its ok to admit stuff. Hey i admited im weak first but everyone wants to be tough guys here so them them talk their dick size up too.
We are human after all. :lol:
Post Posted: Tue Sep 01, 2009 6:34 pm
haha....funny stuff.....
sierras are a piece of piss. i'm used to lifting vit boxes in all the time.
and i have never had to cut anything from the g/box mount.
and sorry BlueSuzy...........................i am hung :wink:
Post Posted: Tue Sep 01, 2009 7:41 pm
and sorry BlueSuzy...........................i am hung like an ant :wink:
fixed. :lol:
Vehicle: '92 Sierra
Post Posted: Tue Sep 01, 2009 8:04 pm
You don't have to cut anything off Joe. It just makes it easier and I'm all about working smarter not harder........ :lol: Back when I had a bodylift it was heaps easier to get out. I only slotted the mount after going abck to standard body height.
P.S Blue my dick is massive.........ly dissapointing :oops:
Post Posted: Wed Sep 02, 2009 3:29 am
Buhahaha :youdaman:
Post Posted: Wed Oct 21, 2009 8:30 pm
I cannot figure out whats holding the gearbox in.
I've taken off/undone everything. I can only get it to slide along the studs about 1/4" away from the engine, and then it something hits and i cant get it out.
The only thing i can think of is the starter motor, but i can't see it hitting anything??
http://www.auszo
Post Posted: Wed Oct 21, 2009 9:47 pm
Did you take the gear stick out?? :roll:
Post Posted: Thu Oct 22, 2009 9:05 pm
haha. yes.
http://www.auszo
Post Posted: Thu Oct 22, 2009 9:17 pm
Hybrid wrote:
...I suggest you pull yours out while taping it just so we can get some respect back for you...
what are you talking about? :lol: :lol: :D
Post Posted: Thu Oct 22, 2009 10:49 pm
An you called me a big girls blouse coz I admitted defeat, lol, shame. :lol:
Post Posted: Thu Oct 22, 2009 11:17 pm
got the cover with the 2 10mm bolts off the bottom of the gearbox ?
Post Posted: Sat Oct 24, 2009 12:02 pm
Buhahahaha, now you know i was joking :lol:
Post Posted: Thu Oct 29, 2009 5:44 pm
turns out i had to pull the starter off.
thanks anyway. Also had to pull the front drive shaft as bellhousing got stuck between it and the exhaust.
On a side note, having my jackshaft out, i just noticed that the input flange on the transfer has a bit of play... how much is normal? I can twist it about 3-4mm (along the circumference of the flange) before it 'takes up'.
Also, with the case in 4 and the front drive shaft disco'd, i noticed theres alot of play in the rear diff (backlash). I can twist the drive shaft back and foward somewhere between 1/8th and a 1/4 of a turn (1/6th?)... again whats normal here? would appreciate if someone could check on their car?
http://www.auszo
Post Posted: Thu Oct 29, 2009 6:36 pm
locker in the rear? sounds similar to mine
Post Posted: Thu Oct 29, 2009 6:44 pm
yep lockright/auto. its only been like it since i put the locker in so i thought it might be because of that.
http://www.auszo
Post Posted: Thu Oct 29, 2009 6:45 pm
I had mine out 3 weeks ago and I got help with stabbing it back in but that is just becasue I like my back. But I could have done it myself. Now that was in a shop on a 2 post not on the ground.
And to add to that I didnt have to cut anything.
Post Posted: Fri Oct 30, 2009 3:59 am
if you are doing it on the ground with no jacks etc. make sure the dowels (little cylinders) stay in the engine not the gearbox... hard lesson learnt yesterday. there is not much clearance but with a little effort (about 8hrs if like me you had no idea) and a bit of brute force it should come out. it"s not that heavy either, i'd say 25kg.
Users browsing this forum: No registered users and 39 guests
