It is currently Sun Oct 25, 2026 2:51 am
Vehicle: 2013 JImny
Post Posted: Tue Aug 05, 2014 12:02 am
Came across this, thought id put it up in case anyones missed it
http://www.jimnybits.co.uk/shop/jimny/suspension/jimny-anti-roll-bar-/-sway-bar-quick-disconnect-kit/prod_1392.html
Post Posted: Tue Aug 05, 2014 5:55 am
Im building something similar currently. As ghetto but hopefully a touch neater then that...
Post Posted: Tue Aug 05, 2014 6:21 am
Screw the bolt
put a spring loaded pin on a bike gear shifter cable
incab swaybar disconnect
Vehicle: zook
Post Posted: Thu Aug 07, 2014 9:14 pm
It looks like it would stiffen up the swaybay quite a bit between the bends when it is pinned. Even less body roll on the road? A sway bar needs to twist to some degree.
IMO the sleeves need to be shorter but I am sure they have designed this reach a certain strength requirement.
Not a bad solution otherwise.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Fri Aug 08, 2014 8:42 am
IMO the jimny could use a slightly stiffer front swaybar onroad, expecially if your runing 235's and have much more rubber in contact.
it would mean the front inner wheel might lift causing understeer rather then the back flicking out on roundabouts.
Vehicle: 91 Tin Top
Post Posted: Fri Nov 14, 2014 3:22 pm
I'm just throwing these up here for future reference to come back to if I ever get around to making my swaybar disconnect.
I like the APIO style and have been playing around with google translate to find some more info on how they actually work.
This is the coupling;
The earlier comments on this thread had me thinking about ways I could make a pin to get back in. I was surprised to see that this is the couple at full flex;
The pin on the APIO system is long, with a slight taper and a normal cotter pin to lock it in place;
And some clever bugger thought of this to store the pin while wheeling;
There is obviously something inside the coupling to keep it from separating while rotating.
I'm guessing the bigger section is put on the drilled side before a sleeve or end cap is welded on to the end of each section, then the bigger section is pulled back over the sleeves and welded onto the non drilled side to make a fix coupling the can only rotate.
That last bit is just a guess and if I ever get keen to make one for myself I'll make a couple of small tests before cutting a bar from the wreckers.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Nov 17, 2014 9:01 am
my ankle would get smashed against that pin holder
Vehicle: 91 Tin Top
Post Posted: Mon Nov 17, 2014 11:10 am
You mean your passenger's ankle would get smashed with that pin holder.... :)
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Nov 17, 2014 11:20 am
teaching my GF to drive ATM. reduction gears are awesome when someones learning to use a clutch, practically impossible to stall in lowrange
Users browsing this forum: No registered users and 264 guests
