It is currently Wed Oct 28, 2026 5:24 am
Vehicle: 99 Jimny
Post Posted: Thu Aug 21, 2014 12:55 pm
Hey guys, I was messing arround with the jimny on the weekend, nearly boxing it up after the sr20 install and I must have had a few beers too many coz i decided to pull this out of the front diff to see what it was, I have rebuilt the diff with trial jimny axles and cvs (26 spline) and used rear jimny side gears to suit) they've also had every bearing, seal, etc replaced though I left the centre open as per factory as I am not a big fan of locking the fronts personally.
Anyway I have attached a picture of what I have removed, And quickly realised I shoudln't have, though perhaps considered the work I have undertaken I should find the procedure to what FB grops tell me is a backlash adjuster? I've been all over google and in the manual and I cant find anything... is anyone able to shine some light on this?
Thanks again
The pin and its lock nut are # 22 / 23 respectively
Post Posted: Thu Aug 21, 2014 1:01 pm
its called a thrust bolt
Post Posted: Thu Aug 21, 2014 1:06 pm
it says tighten bolt in to 1.5NM
back it off half a turn
hold the bolt still and tighten the nut (with locktight)on it to 85NM
Vehicle: 99 Jimny
Post Posted: Thu Aug 21, 2014 1:11 pm
thankyou sir, thats basicly what i did by guessing after id removed it but i will use that exact torque and redo this weekend. much appreciated.
Users browsing this forum: Google [Bot] and 302 guests
