It is currently Wed Oct 28, 2026 11:32 am
Vehicle: Suzuki Stockman
Post Posted: Mon Aug 25, 2014 10:45 pm
Hi people I just joined this forum and I apologize in advance if this topic has already been covered. I did use the search function but did not find anything on the subject. I just got a 98 model Stockman with one of those 1000cc Maruti engines in it...and yeah I want a bigger one for it.... I'm wanting to know what a suitable conversion motor would be for doing a bit of off road work as well as being able to sit on around 120km/ph on the highway.
Cheers.
Vehicle: ***
Post Posted: Mon Aug 25, 2014 11:22 pm
5.7 LS1
Post Posted: Mon Aug 25, 2014 11:33 pm
Tyron wrote:
5.7 LS1
Have you done this conversion?
Post Posted: Mon Aug 25, 2014 11:37 pm
lol ignore that guy... most common swap is a vitara 1.6 EFI motor. Do a search, there's a TON of info on how its done =)
If you're running larger tyres you will want to address your gearing.
235/75r15 would want 4.16 tcase gears, 30-31" tyres will want 5.14 or 6.5 depending on engine size (5.14 for 1.6 and 6.5 for 1.3 IMO).
Vehicle: ***
Post Posted: Mon Aug 25, 2014 11:39 pm
It's a joke, I'm sorry.
Google "G16B sierra conversion" you should get some hits.
Lots of things have been dropped into them. 4AGE G13B CA18 SR20 even rotaries.
Just google search
Post Posted: Mon Aug 25, 2014 11:40 pm
Righto mate lol cheers.
Post Posted: Mon Aug 25, 2014 11:44 pm
Thanks guys. I thought you might have been joking Tyron. But I guess nothing is impossible lol. Thanks for the info Alien. I will get googling and see what I can find.
Post Posted: Mon Aug 25, 2014 11:45 pm
You dont need google - use the search button up the top of the page =)
Vehicle: WT sierra, GU CRD
Post Posted: Mon Aug 25, 2014 11:57 pm
Just google search
A bit more than an engine swap:
viewtopic.php?f=4&t=44858
I love ZD30. :)
Vehicle: Suzuki Sierra Trayback
Post Posted: Wed Aug 27, 2014 8:12 pm
I'm in the process of gathering parts for the Vitara 16A conversion on my Maruti, It's not as straight forward as the 1.6 into a a 1.3. You will need a 5sp gearbox to bolt up to the 1.6 eng, 1.3 clutch, flywheel and 1.3 clutch bracket. A Ben T eng/gearbox adapter, narrow Vitara starter motor. Need a 1.3 oil pick up (modified) and sump. No doubt replace the small radiator with a larger donor unit. Have to modify the engine mounting brackets or weld in 1.3 ones, fit a body lift so the bonnet clears the donk. Theres probably other items needed that I've forgotten. If you go for the EFI engine this will add further mods, but no doubt worth it.
I have 30x9.5xR15 on mine and will be fitting 4.6 Nitro diff gears, but will never travel at 120klm's an hr.
Nick
Post Posted: Wed Aug 27, 2014 8:29 pm
Thanks Nick for the info. I would be interested in following your progress with your conversion if that's okay.
Users browsing this forum: No registered users and 327 guests
