It is currently Sun Oct 25, 2026 7:56 pm
Vehicle: 2002 Jimny
Post Posted: Tue Aug 26, 2014 8:41 pm
Hey guys,
I have a lightbar which is to be mounted to my roof basket shortly, however I am unsure as to how people have wired theirs.
Was thinking of running a new line down with the aerial, or perhaps through the foot of the roof rails.
Anyone know a better way?
Cheers!
Vehicle: Suzuki Jimny 2009
Post Posted: Tue Aug 26, 2014 8:59 pm
Take a look through Zukenutters build thread. He has ended up with a cable gland through the roof.
Something like this one.
http://www.ebay.com.au/itm/150957283432 ... 1423.l2649
Vehicle: 2002 Jimny
Post Posted: Tue Aug 26, 2014 9:56 pm
Yeh from memory he drilled a hole through the roof - not 100% keen on that path. Mostly because I know I will mess it up somehow. Haha.
Vehicle: 2012 jimny
Post Posted: Wed Aug 27, 2014 7:21 am
I ran mine up the drivers side on the windscreen in a temp plastic stick on duct from bunnings. Works well and looks neat enough and isn't permanent.
Vehicle: 2002 Jimny
Post Posted: Wed Aug 27, 2014 9:35 am
Cool, thanks Dan. Might look at coming up with something similar. Thanks mate!
Vehicle: 91 Tin Top
Post Posted: Wed Aug 27, 2014 9:45 am
I'm sure you could use your snorkel to hide most of the conduit. It would just be the last bit from the top snorkel bracket to the antenna that would be most obvious.
Vehicle: 2002 Jimny
Post Posted: Wed Aug 27, 2014 10:08 am
That was another thought I had Pete. I read of people even putting it inside the snorkel, but I think drilling holes in the top and bottom to run the cable sort of defeats the purpose of having the snorkel in the first place. Haha.
Post Posted: Wed Aug 27, 2014 12:16 pm
This is what I did.
Only mod the antenna to fit the cabling.
Vehicle: 2002 Jimny
Post Posted: Wed Aug 27, 2014 1:21 pm
Perfect! Thats exactly that I was thinking of. Especially with the disconnect.
Post Posted: Wed Aug 27, 2014 9:05 pm
My plug style gland is still leak free but I should have just done the antenna hole, so much simpler.
Vehicle: 2005 Suzuki Jimny JLX
Post Posted: Thu Aug 28, 2014 9:19 pm
I saw a light bar mounted on a Jimny roof in a car yard. The wiring had been run down the hinged side of the back door and then in behind the tail light
Post Posted: Thu Aug 28, 2014 9:24 pm
Goes into the rubber boot behind the tail light
Vehicle: 2002 Jimny
Post Posted: Thu Aug 28, 2014 9:36 pm
Certainly an interesting approach. I would be worried about running the conduit from the rail foot over the roof into the cavity - although only a small run, I think it would look quite ugly to be honest.
Thank you so much for the photos - I hope you didn't stop just to get photos for this thread. Haha.
Post Posted: Fri Aug 29, 2014 6:05 am
No worries. I took these pics about 2-3 months ago. I'm going to do the same for my Jimny. (Have a custom roof basket, no rails). I have two light bars mounted to my roof now, just not wired up
Post Posted: Fri Aug 29, 2014 7:14 am
I had my old Jimny roof lights wired similarly to this ^^. Worked fine but voltage drop may be an issue with such a long path.
Users browsing this forum: Google [Bot] and 102 guests
