It is currently Tue Oct 27, 2026 2:41 am
Vehicle: suzuki sierra '94 (sj70)
Post Posted: Tue Sep 09, 2014 12:05 pm
im looking at getting carpet and some body bolts and also sliders and flares from a NT and wondering if they will fit in my WT sj70??
Vehicle: WT sierra, GU CRD
Post Posted: Tue Sep 09, 2014 12:09 pm
Having had both, but my NT was un carpeted: I'd say it will fit.
Flares, you might have to re-drill the metal tabs on the body work, I think they have different screw spacings. I also imagine sliders should change over but can't say for sure because my NT was LWB.
I looked around forever to find a set of NT flares.
I love ZD30. :)
Post Posted: Tue Sep 09, 2014 1:02 pm
the NT flares are actually the plastic type ones.
Post Posted: Tue Sep 09, 2014 1:06 pm
Why would you want NT flares on a WT? They won't be wide enough to cover even the stock tyres.
Post Posted: Tue Sep 09, 2014 1:22 pm
they did do the narrow track plastic flares which were the same size as widetrack flares..87-88 right on the crossover. I wouldn't be fitting up the plastic ones if you smash against things. They crack and smash easy. Same holes from memory.
Post Posted: Tue Sep 09, 2014 1:26 pm
The plastic flares were the cross over WT flare on the 1988.5 model, I wouldn't say that they were NT flares at all considering they had WT diffs.
Post Posted: Tue Sep 09, 2014 1:28 pm
They might mount the same, which is not helpful to the OP, who has a metal flare WT anywho.
But agreed.
I love ZD30. :)
Vehicle: Drover pickup turk
Post Posted: Tue Sep 09, 2014 2:14 pm
FWIW WT flares won't bolt onto the spot welded bracket on a NT
I like the tuna here
Post Posted: Tue Sep 09, 2014 5:00 pm
they are the bushwacker flares type flares so would be plently wide enough
Post Posted: Tue Sep 09, 2014 5:15 pm
FWIW 1981-84 1ls had different transmission tunnels so if it's from one of those then you might have issues with fitment.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 238 guests
