It is currently Wed Oct 21, 2026 7:15 pm
Post Posted: Fri Sep 04, 2009 1:56 pm
Does anyone have any recomendations about where to go for uprated parts in the Brisbane area or northern NSW? (I'm in Glen Innes) I'm after someone familiar with modifying zooks and not too pricey for springs, shocks, body lift kit, brake lines etc.
Thanks
Post Posted: Fri Sep 04, 2009 2:43 pm
Body lift can be delivered to your door from Just_Cruisin. Brake lines will have to be made to suit so use your local brake shop.
Post Posted: Fri Sep 04, 2009 11:18 pm
What lift are you doing mate?? I have 2 body & 2 suspension.. I didn't need any longer lines, just took the front passenger side out of its carrier. Just a thought, you might actually want to do it properly...however i'm a bit less caring, still has the same effect at the end of the day. Look at ebay and search onlineautoparts, they have lift kits at a very good price. Hope this helps ya out a bit.
Post Posted: Fri Sep 04, 2009 11:57 pm
rusho81 ive just got a body lift and 2 inch suspension lift, missing the struts. how much were ur struts from pedders?
and you say you dont need extended lines for coily? ive got a coily too and wasnt gonna put the kit in yet because i havent got xtended lines
Online
Post Posted: Sat Sep 05, 2009 12:02 am
this is a sierra with 40mm springs and a bodylift.
have a look at the brake line. i could nearly hear it humming in the wind.
Post Posted: Sat Sep 05, 2009 12:03 am
Who needs brakes?? Thay only slow you down
Post Posted: Sat Sep 05, 2009 12:32 am
I've only got the dodgy lift set from that ebay store i mentioned. Shep is probably right, extended lines would be ideal, but we don't live in a perfect world, extra cost, bleed brakes etc also, but i'm a tight ass & lazy!!! I haven't had a problem thus far, touch wood.... I left the zippy a bit loose to allow for a bit of horizontal movement, each to their own mate. Will pic it for you tomorrow after I fuck around with a head gasket.
If memory serves me right I think pedders lifted struts were about $500 ish for the pair, can't remember though mate. That was for the top of the range they stock, again don't know what it was called. Kinda switched off when they started talking about spending $2500 on suspension upgrade!!!!
Users browsing this forum: No registered users and 120 guests
