It is currently Sun Jun 07, 2026 10:13 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2
Post Posted: Fri Sep 12, 2014 10:25 am
AckerDackerly wrote:
For those with limited fabbing skills or is tired of re-inventing the wheel, this product works great:
http://www.zuksoffroad.com/Heavy-Duty-Bolt-kit_p_56.html
I hope that this helps
Over $100 landed in Australia for four bolts and some tube looks pretty steep to me. (Even $30 looks steep for what you get)
WOW.
Has our dollar jumped that much in value???
Holy cr@p!
-Ack
http://www.acksfaq.com
88, 88.5 SJ413
Post Posted: Fri Sep 12, 2014 11:34 am
Freight buddy, freight.
Vehicle: 1984 holden drover (lwb zook)
Post Posted: Sat Sep 13, 2014 9:57 pm
these good? fit on the m12 bolts perfect and are stainless steel
Post Posted: Sat Sep 13, 2014 11:26 pm
beefcake2000
Post Posted: Sun Sep 14, 2014 7:31 am
They look awesome.
Don't look like stainless though - more like plated? Not that it matters.
Vehicle: vits
Post Posted: Sun Sep 14, 2014 10:01 am
tanshi wrote:
I personally like the the idea of ubolts around the crossmember tube. or big end bearing caps if you can find some the right size.
This is how ARB do it.
Post Posted: Sun Sep 14, 2014 12:12 pm
Thats a good idea im Going to add a bit like that with the u bolt just for extra sturdieness
Post Posted: Sun Sep 14, 2014 12:23 pm
^^^ this guys knows how to listen to sound advice. 8)
Post Posted: Sun Sep 14, 2014 1:17 pm
Me?
Post Posted: Sun Sep 14, 2014 2:59 pm
Me?
yeah, you. Armsup
Post Posted: Sun Sep 14, 2014 3:20 pm
No point in asking if i dont listen to the advise and pluss being 17 i dont know everything in the world so may aswell listen to people that do know a fair bit
Post Posted: Sun Sep 14, 2014 3:35 pm
Armsup
Post Posted: Sun Sep 14, 2014 5:36 pm
fark, you'll go along way kid. 8)
this is another option. viewtopic.php?f=14&t=7930&hilit=bar
i thought i might put this in here as it is a very strong way of mounting winch bars.
bashed some pipe into the front chassis rail
trimmed the chassis rail leaving around 10mm sticking out from the body mount.
made a plate to slip over the chassis rale and to tie in with the body mount.
ball has the measurements for these plates and can make them.
glue the plate to the chassis rail and the body mount.
make a plate to bolt to the chassis plate
then make ya bar around the plate and it will be as strong as fuck. :wink:
notch the plate to fit the tube for the strongest results.
sit around for a bit while i whinge about how hot it is. :D
Vehicle: vits
Post Posted: Sun Sep 14, 2014 5:50 pm
I call bullshit....
......said no 17 year old, ever 8O
I don't know if this is any use to you as I am not familiar with the Sierra chassis. This is a pic of another mount on an ARB Vitara bar...
...it clamps around a flat vertical section of the pretend cardboard chassis. The drilled and tapped flat bar is 10mm, fixed with M8 bolts.
The ARB SWB Vitara bar also picks up the factory bumper points, which gives it 6 mounting points in total.
Post Posted: Sun Sep 14, 2014 7:48 pm
britvit wrote:
I call bullshit....
What do you call bullshit on
Fuark i wish i had the equipment and stuff otherwise i would do that plate like shep for sure haha maybe on the next one when i make a winch bar
As the bar i got of my mate when on sits a slight bit forward and low
Vehicle: vits
Post Posted: Sun Sep 14, 2014 8:10 pm
bibby wrote:
britvit wrote:
I call bullshit....
I was amazed that someone your age came on here and listened for a change! Well done mate Armsup
Post Posted: Sun Sep 14, 2014 8:22 pm
Oh hahaha well gues im one in a million arnt i
Vehicle: '85 Sierra LWB Ute, Lkd 33's
Post Posted: Mon Sep 15, 2014 6:05 pm
Buy some 20mm solid bar, cut it up to the right length and take it down to any machine shop and ask them to bore a 12.5mm hole through each piece.
I did this and I think I paid $5 a hole or something. Well worth it IMO.
Vehicle: WT sierra, GU CRD
Post Posted: Mon Sep 15, 2014 6:22 pm
Hey Bibby, where'd you find those if you don't mind my asking?
They look good.
I love ZD30. :)
Post Posted: Mon Sep 15, 2014 6:29 pm
had some super pro suspension bushings in the shed bud and they just happened to be the metal insert things for the bushes, so turned out pretty well, ended up selling that bar just today though gona get one made like sheps method.
Post Posted: Mon Sep 15, 2014 6:38 pm
Nice, I might have a set there actually.
Cheers mate.
I love ZD30. :)
Post Posted: Mon Sep 15, 2014 7:59 pm
yeah good luck bud
