It is currently Fri Jul 24, 2026 5:57 pm
Post Posted: Fri Sep 04, 2009 11:45 pm
well i've found a few spots on the front section where the wipers sit on my LJ and its in a bugger of a spot because it where the sheets of metal overlap and has gotten underneath a sheet and at it out.
Whats the best way to fix it other then chop it out as its only the szie of a 50 cent piece. Was loking at using Septone rust converter and the filler stuff, seems simple enough.
Also what should i do about surface rust? the has some big patches where its come the the paint but has eaten holes through.
Any info is apreciated. Cheers Shelby
Post Posted: Sat Sep 05, 2009 12:08 am
Size of a 50c piece on the surface, will be bigger than that underneath, cut it out!!!!!!!!!
Post Posted: Sat Sep 05, 2009 12:14 am
well its where the sheets of metal overlap, so its only eaten a hole in the top layer and layer underneath is fine.
Post Posted: Sat Sep 05, 2009 12:52 am
wire brush the be jebus out of it & seal it, bog will sweat & make things worse so use a spray primer/ filler, can get in a can if you don`t have compressor.
That`s how I would do it.
But Gv`s don`t rust, not yet anyway.
Post Posted: Sat Sep 05, 2009 2:18 am
be4st way to fix rust is to pay someone that does it for a living.
Thats the easiest way but prob the most expensive way too.
B4t
Post Posted: Sat Sep 05, 2009 3:05 am
no it isn't, panel beaters suck, everything i have ever had fixed by someone else has rusted, anything i did myself is good
Post Posted: Sat Sep 05, 2009 3:42 am
So you say to use spray putty? well i might give the spray putty a go with some metal tech filler. if worst comes to worst i'll just have to cut it out and tach weld it from the inside, have no clue how to weld but im sure i could find someone to.
Users browsing this forum: Google [Bot] and 374 guests
