It is currently Sun Oct 25, 2026 5:30 am
Vehicle: Suzuki Vitara
Post Posted: Thu Oct 23, 2014 9:14 pm
Hey, i have a SE416 Vitara, i have a problem, my inner Cv in the front has no travel, it is an aftermarket one, but its usable travel is 15 degrees, is this normal?
I have had 2 different brand of CV shaft in the front, and thier all the same, the outer joint is great, i will never snap it because the inner one binds along time before.
any help or advice would be appreciated.
I am thinking of widening the front track of my vitara, and i was wondering if the longer(40mm aprox) Cv shafts of the later model vitaras could easily be modified to fit a 22 spline diff?
aka the 26 spline inner cv is knocked of and replaced by a 22 spline for the drivers shaft, and do the outer hubs have the same spline count?
Post Posted: Thu Oct 23, 2014 9:21 pm
is it the normal burfield style of joint or the retarded tripod roller type that's binding?
EDIT: got any diff drops & how much lift you running?
EDIT EDIT: yeah you can make a hybrid shaft, but they really all need to be genuine CV's to get it to work.
Post Posted: Fri Oct 24, 2014 3:55 pm
I believe it is a Tripod model, where would it be possible to get a Burfield style joint?
I have had Repco ones, and they are crap, same thing, these are Ebay ones, and i got a quote for some genuine ones, and they were over $1000 each
Users browsing this forum: Google [Bot] and 162 guests
