It is currently Tue Oct 27, 2026 6:26 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
Vehicle: Jimny 08'
Post Posted: Fri Oct 24, 2014 6:19 pm
Hey guys so iv'e had a problem with my rear speakers for ages, and they really have just been all around a big pain in the ass.
Mainly because i picked up a pair of cheap boxes for 6x9 speakers, that when 4wding kind of just flew around the back of the car, and damaging all the connections i made.
Image < I Call them shitboxes
Image <
Their inability to stay put has broken two sets of speakers
Anyway my idea was to mount the speakers in the side pockets, as i dont even use them and really its a perfect spot, much like this
Anyone got suggestions on how to go about it? I've redone all the wiring/soldering and there is enough cable for each side and whatnot.
Cheers,
Cam
My Jimny
Vehicle: 09 Jimny Sierra
Post Posted: Fri Oct 24, 2014 6:31 pm
Fibreglassing? That second pic would be what i use
Post Posted: Fri Oct 24, 2014 6:33 pm
build a speaker box using the tried & tested technique of mdf, cloth & fiberglass.
Vehicle: Jimny 08'
Post Posted: Fri Oct 24, 2014 6:40 pm
Fiberglass would be nice, but wouldn't have a clue where too start haha, mdf box could work well! probably have to play around with a few shapes i suppose!
If i didn't go with the sides, what have other people done with their rear speakers?
My Jimny
Post Posted: Fri Oct 24, 2014 6:46 pm
I have then in those rear vent things, with the fiberglass you just make a sketeton with mdf and put the special fiberglass cloth on it to get the shape and then apply the matting, then smooth with filler, probs not the right way but somthing like that
Post Posted: Fri Oct 24, 2014 6:51 pm
whoops, tried posting a youtube vid as a pic... try this one for size.
Vehicle: Jimny 08'
Post Posted: Fri Oct 24, 2014 6:57 pm
ahah hectic, im thinking little 5x7's ill take a quick snap of the placement i came up with! easier to build a box where im thinking than trying to wedge in the side rests
My Jimny
Vehicle: Jimny 08'
Post Posted: Fri Oct 24, 2014 7:03 pm
So this is where I'm thinking, this is a 6x9 speaker though, probably use 5x7's
Fitting a box here will be much easier I think!
My Jimny
Post Posted: Fri Oct 24, 2014 7:06 pm
why not buy just speakers that fit. :?
Vehicle: Jimny 08'
Post Posted: Fri Oct 24, 2014 7:33 pm
In the rear stock slots?
Don't think it would provide enough range/ depth of sound, dont want it too be loud, just want the quailty, i have a nice speaker system at home, when i jump in my car its like my ears are burning ahah
But im open to all ideas hey, and ideally the easiest option!
http://www.danbp.org/w/Installation_of_ ... zuki_Jimny
My Jimny
Vehicle: Jimny 08'
Post Posted: Fri Oct 24, 2014 7:41 pm
So just had a solid google and search, using those rear slots, i could get some good mid range speakers, and then install an underseat amp/sub that give the depth. What you guys reckon? easier than building unnecessary boxes that take up space?
My Jimny
Post Posted: Fri Oct 24, 2014 7:47 pm
If you really want to get maximun audio fedelity, you can cut it out a bit more and put a 6x9 lol, i think best bet is what ill end up doing, if u have no rear seats, make a box behind the cup holders and get a 10" sub, they fit decently, you dont get that great of bass response with an active slimline sub, i have german mistero 4" crossovers with tweeters at the front and 4" rockerfostgates in the back, they work well, but if anything i need more mid then low, might make some boxes behind the seats and add some 6x9s
Post Posted: Fri Oct 24, 2014 7:50 pm
^^^ 6x9's are a poor solution to sound quality.
if i still gave a shit about sound quality i'd be doing something like that, some quality speakers in the factory location & using the area you were looking at using in the back right hand corner build a vertical subwoofer enclosure that hugged the profile of the C pillar, inner wheel arch, floor, side panel & fill it with a quality 10" dual voice coil sub... right hand side cause that's the side the door hinges from so you won't be having to work around it all the time.
something like this but built to the space you have.
Post Posted: Fri Oct 24, 2014 8:00 pm
Whats good for mids altari? 6"?
Post Posted: Fri Oct 24, 2014 8:08 pm
i'd waste my money on some 6" splits & a sub over 6x9's personally.
Vehicle: Jimny 08'
Post Posted: Fri Oct 24, 2014 8:16 pm
my 6x9 were great for quality (well compared to just the front 2), they were 3 way's but yeah they flew around the back like gravity didn't exist, just more of a problem than a solution
haha yeah i'm not worried about it being loud, not like i'm an old man ahah but quality is my dilemma.
this http://www.motoquipe.com.au/buy/fusion- ... Av_i8P8HAQ
Seems like a decent solution, and does save me from building a box,
a box would be a good project, but sure i would fuck it up somewhere along the way :/ haha
My Jimny
Post Posted: Fri Oct 24, 2014 8:22 pm
i hope that sub/amp combo is waterproof. :wink:
Vehicle: Jimny 08'
Post Posted: Fri Oct 24, 2014 8:29 pm
ahah yeah i have read some stories about water crossings with an under seat amp... none of them good :/
need some of that waterproof nano coating :D
My Jimny
Post Posted: Fri Oct 24, 2014 8:43 pm
Marine speakers haha
Vehicle: Jimny 08'
Post Posted: Sat Oct 25, 2014 12:06 pm
haha looks like ill be doing the underseat amp/sub, and using the two back speaker slots. Will sound good, and saves me from making boxes and taking up room in the back! Plus will be just as cheap!
My Jimny
Vehicle: 2000 Jimny
Post Posted: Sat Oct 25, 2014 3:48 pm
i installed some 6.5" 3 way speakers into the factory spots today:
standard hole is 5", so i made a speaker bracket on each side using approx 6mm mdf. the speaker is in upside down, but that's to clear the terminals. on one side & bottom of the bracket i had to cut the edge flat to match the shape of the car. there was enough clearance with the side panel replaced so it wasn't touching the speaker, but i still removed the lip on the inside of the panel with a rotary tool just to be sure.
Vehicle: Jimny 08'
Post Posted: Sat Oct 25, 2014 4:20 pm
oh good thinking haha, nice and out of the way! Bit cheaper than an underseat amp sub
My Jimny
Vehicle: 2000 Jimny
Post Posted: Sat Oct 25, 2014 7:11 pm
i'm still keeping my eyes open for something like that as well though, may be better to have a regular sub/amp that i can remove easily though as i pretty much use under the seats for storing all my crap.
Vehicle: Jimny 08'
Post Posted: Sun Oct 26, 2014 11:42 am
Yeah I like too store my air compressor hose and whatnot under the seat, but if I got a small amp, probably wouldn't get in the way, and could still fit a few bits and pieces under there.
My Jimny
Vehicle: Jimny 08'
Post Posted: Sun Oct 26, 2014 4:30 pm
How much space do you reckon there is between the plastic side panel (when put back in place) and the cutout/speaker hole? considering doing the same with 6" but depth is my concern :/
My Jimny
Vehicle: 2000 Jimny
Post Posted: Sun Oct 26, 2014 4:46 pm
with the speaker & the spacer i'm guessing there was maybe another 2mm, so possibly 10mm all up.
Vehicle: Jimny 08'
Post Posted: Sun Oct 26, 2014 5:00 pm
alright cheers, absolutely cant make up my mind ahah so many options!
My Jimny
Vehicle: Jimny 08'
Post Posted: Sun Oct 26, 2014 7:35 pm
Just an update for those interested I brought these
http://www.soundmaster.com.au/Polk-Audi ... ers/db501/
Seem like good quality speakers!
My Jimny
Vehicle: 2000 Jimny
Post Posted: Mon Oct 27, 2014 8:54 am
they should drop straight in for you, will save a ton of trouble.
have you got speakers in the front ? i think the holes are only 4".
Vehicle: Jimny 08'
Post Posted: Mon Oct 27, 2014 12:39 pm
Yeah got a pair of these little guys
https://www.jbhifi.com.au/gps-car-audio ... ers/54257/
Nothing special, got them when i first got the jim, but they have done a good job! and sound is decent for 4" speakers, apart from a bit of rattling when volume is too high, when i redo the back ones, might try fix them in a bit tighter.
My Jimny
Users browsing this forum: No registered users and 170 guests
