It is currently Mon Oct 26, 2026 1:58 pm
Vehicle: V6 autolocker rear and so much
Post Posted: Sun Oct 26, 2014 9:14 pm
Is the auto trans mounted too the h25a, in the grand vitara's a 3speed with overdrive or ?
Would anyone possibly know weather or not the old h20a vitara shear the same auto box as its bigger bro the 2.5 GV ?
Post Posted: Mon Oct 27, 2014 7:24 pm
Mine is 4sp with overdrive pretty sure
Post Posted: Mon Oct 27, 2014 10:04 pm
The SQ625 (upto 05) has an 03-72LE (which is an AW4 derivative) it's 3 speed PLUS overdrive for a total of four speeds - I believe the SV620 also used the same transmission.
Post Posted: Fri Oct 31, 2014 3:41 pm
I have the SV620 an your right it's definitely is a 3 speed plus overdrive,
i was hoping the GV used the same trans as my timing chains need replacing (h20a), plan ats instead of replacing the chains i want to swap a h25a (with loom an ecu) in foe the extra horse's, i need too doo more research into whether or not i can get the h25 computer to accept my h20 trans..
Post Posted: Fri Oct 31, 2014 4:40 pm
that wont work
Post Posted: Sun Nov 02, 2014 6:19 pm
that wont work
How so....
Users browsing this forum: Google [Bot] and 309 guests
