It is currently Sun Jun 07, 2026 6:23 pm
Post Posted: Mon Nov 03, 2014 3:51 pm
Noob question. Do vit p/s have internal stops that can be adjusted?
Post Posted: Mon Nov 03, 2014 6:18 pm
Internal stops....No.
Can't say I've ever seen a steering box with adjustable internal stops.
Vitara has steering stops on the pitman arm but they are more for limiting steering angle at the wheel than at the box.
Post Posted: Mon Nov 03, 2014 6:22 pm
Thanks. Going to have to make something up then to reduce steering lock
Post Posted: Mon Nov 03, 2014 6:32 pm
Pitman arm or hub is easiest.
What's the vehicle/setup?
Post Posted: Mon Nov 03, 2014 6:49 pm
Hub stops might be the go
Lwb tray back with 3-link front with the arms running on the out side of the chassis. Wt diffs, 33's on 8" rims
Post Posted: Tue Nov 04, 2014 5:34 am
Sounds cool. Arms outside chassis won't allow much if any triangulation though.
Hub stops seem to be the industry solid axle standard.
Post Posted: Tue Nov 04, 2014 6:15 am
The arms on the out side of the chassis were to eliminate any anchor points
I'll knock some hub stops up next time I'm home
Users browsing this forum: Google Adsense [Bot] and 4 guests
