Hi, I urgently need help with the following. I have found some TD Jimny springs for sale. He has told me that they are 2.5" lifted springs. He gave me that part number that is written on them which is TDC825. On TDs website, they only kit they have with these springs is the 80mm lift and that they are for the rear. He has a photo of these TD springs next to Jimny stock suspension and they look exactly the same length as the stock fronts.
Can these (as specified by TD) 80mm lifted rear spring be put in the front and provide a lift?
Joined: Wed Nov 24, 2010 7:58 am Posts: 11092 Location: Mandurah.W.A.
Posted: Tue Nov 11, 2014 8:30 pm
It may provide lift but the ride would be shit. They are the same length because lifted springs are often only a bit longer than standard springs but have a higher spring rate which provides the lift
_________________ Tell my arse, he actually gives a crap!
Users browsing this forum: Google [Bot], winchzook and 186 guests
