[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Heideisadog
Joined: Fri Jun 21, 2013 1:27 pm Posts: 403 Location: Canberra, ACT
Vehicle: 1996 Leaf Sierra - Soft Top
 Posted: Thu Nov 13, 2014 9:20 pm |
So I have just recently started to get significant vibration through the floor on the drivers side. Actually I'm not to sure if it happens on both sides, should Probay get someone to check.. But it happens around the 2500revs in 2-4th gear. Never had it happen till just recently (past few weeks) What could be causing this? Uni joints starting to die? That's the only thing I thought could cause this. Are the drive shafts/ tail shafts balanced or weighted? I have had them out not to long ago so if so they could Be in wrong? Maybe a bearing somewhere
Sorry if I'm being quite noob with this, just chucking ideas out there!
Thanks, Tom
atari4x4
 Posted: Thu Nov 13, 2014 10:18 pm |
sounds like a uni joint, could possibly be the ones in the jack shaft as they're usually the ones that are forgotten about plus feeling it thru the footwell rather than a shimmy/vibe in the rear.
did you mark the yoke on the unijoint & the flange on the diff & tcase when pulling them & did you line the splines on the slip joint up. i think the sierra's have a punch/match mark on them to line up.
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Thu Nov 13, 2014 10:26 pm |
Siezed unibor broken engne mount
Heideisadog
 Posted: Sat Nov 15, 2014 11:34 am |
Thanks for that guys. Are gresable unis the way to go?
Hmmmm not to sure I did that! Whoops! I marked the slip joint though! I'll have a closer inspection soon!
Engine mounts are all good too.
jdk81
Joined: Sat Jul 18, 2009 11:30 pm Posts: 2372 Location: Ballarat, VIC
 Posted: Sat Nov 15, 2014 2:46 pm |
Sierras have punch marks to correctly align them in phase no need to mark the diff and xfer flanges, and driveshaft yokes.
Sierra driveshafts can be put together unbalanced but still in phase (punch marks 180 degrees out).
Majority of aftermarket unis are greasable. Some have the nipple inside, others have it on a bearing cap. Internal is more protected, but more of a pita to grease.
I prefer jap bearings.
If wheel bearings start to go you sometimes can feel a grinding/vibration through the floor
Heideisadog
 Posted: Sat Nov 15, 2014 9:07 pm |
Okay thanks for that! So helpful!!
Yeah all the ones I have seen so far have been greasable, guess that's what I'll get!
And wheel bearings were done not too long ago so I'll check them but they should be fine. Vibration isn't really a grinding feel abyway
Thankyou!
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 182 guests
