It is currently Sun Oct 25, 2026 12:13 pm
Post Posted: Tue Nov 25, 2014 5:57 pm
Does anyone know how thick a sierra windscreen is?
I had a bit of a lay down on the weekend and can't seem to find a windscreen surround anywhere!
I have winch and snatch blocked the frame fairly well... Bent th doors back so the windows wind up...
It's looking like I will have to make a template and get some laminated safety glass cut
Post Posted: Tue Nov 25, 2014 7:43 pm
Just measured my spare. 5mm thick.
Post Posted: Tue Nov 25, 2014 8:03 pm
Cheaper to buy windscreen from glass mob I'll get u a part # when im sober and at work 2mrw.
Vehicle: 92 wt soft top sierra
Post Posted: Wed Nov 26, 2014 5:17 am
Have you looked on suzistores website they are pricey but you get a brand newy
Post Posted: Wed Nov 26, 2014 5:47 am
I think the idea is his frame is no longer standard shape?
Post Posted: Wed Nov 26, 2014 10:01 am
Cheers guys! Yeah tony that's it... I think it's close to normal but not worth buying a windscreen that doesn't fit.... I can't find a frame anywhere and when I do it's full of rust!
I'm going to ring suzi store and piranha at the em of the week but ill sit down so when they tell me a price I don't fall over!
Post Posted: Wed Nov 26, 2014 10:59 am
Theres a wt for $800 in mill parkon scumtree or ebay
No motor or gearbox, but you could buy it for parts and part the rest out?
Post Posted: Wed Nov 26, 2014 2:38 pm
It's sold! Haha have been all over everything and rang everyone (apart from piranha and suzi store) got onto one but its full of rust.....
Post Posted: Wed Nov 26, 2014 5:13 pm
Could weld up a rhs frame with a lip on it then just get a square piece cut
Bound to happen again if its a toy car
Post Posted: Wed Nov 26, 2014 7:24 pm
It's definatly a toy car! Haha I got a price from suzi store....350 plus postage plus paint plus windscreen... Will be about 600! Bugger that priced up glass and that will be 100....
Laminate safety glass is 6mm.... I think it should be right to go in the stock windscreen rubber?
Post Posted: Thu Nov 27, 2014 4:42 am
Itll be tight the windscreen is normally pretty fiddily to get in
Vehicle: lj81
Post Posted: Thu Nov 27, 2014 5:24 am
When I got a new windscreen for my lj the guy used my old one as a template and cut it out of the same thickness safety glass. You will need to make an accurate template. The guy that did it for me did a lot of hotrod custom screens, is in alexandra which is a fair trip for you for a screen. I imagine there would be someone closer to you though. You will need your frame to be flat no twist in it. Glass doesn't like to bend.
Post Posted: Thu Nov 27, 2014 4:11 pm
Toughy yeah ill make a template! It's flat now after the winch work I did on it after looking at it tonight I think if I do a little bit more a stock screen will go in... But I think I would still rather go the template idea so I know 100% it's going to fit! Haha
Users browsing this forum: Google [Bot] and 190 guests
