It is currently Tue Oct 20, 2026 10:11 am
Vehicle: hkbjk
Post Posted: Tue Nov 25, 2014 11:49 am
Has anyone replaced the bearing in their tensioner pulley (AC and Power Steering 1999 Jimny)? Mine sounds like the bearing has issues and looking at the cost for a new pulley assembly $149! I wonder if anyone has pressed out the old bearing and pressed in a new one and if so do you remember the bearing you used?
Vehicle: 85 ' Drover
Post Posted: Tue Nov 25, 2014 2:19 pm
Its more than likely a standard bearing size, so if you measure it and ring up a bearing shop they should be able to supply you with something that will work.
Assuming it can be pressed out/in etc.
Vehicle: Suzuki Sierra Trayback
Post Posted: Tue Nov 25, 2014 7:48 pm
Done it a few times on Toyota's, bearing cost around $9. Was told that the actual V pulley does suffer from wear in a high klm engine.
Nick
Vehicle: hkbjk
Post Posted: Wed Nov 26, 2014 6:18 am
Ok thanks, I've taken then pulley off so will go to a bearing shop and see what I can find to suit
Vehicle: hkbjk
Post Posted: Thu Dec 04, 2014 5:04 am
Cost for the new bearing was $15 as opposed to $130 for a new pulley and bearing from online. Very simple to tap out the bearing and tap in the new one now is running like a champion again.
Vehicle: 2000 Jimny
Post Posted: Thu Dec 04, 2014 8:58 am
i changed the pulley in mine not too long ago, sourced an ebay unit for about $50 so you're in front of me at $15.
Vehicle: hkbjk
Post Posted: Thu Dec 04, 2014 9:19 am
That was for the whole pulley Im guessing? the $15 was for the bearing only as I did not need to replace the pulley
Vehicle: Suzuki Jimny 2010
Post Posted: Sat Dec 23, 2017 1:16 pm
Bearing is 80mm OD, 50mm ID and 16mm wide. Sealed both sides.
6010 - (2RS - I think 2RS means it has seals both sides). Ask the bearing shop for best one to suit application
'10 Jimny, M18A, 80mm lift kit, 215/75R15 on ROH mags, rear disk brake conversion and front disk vented upgrades. Air Lockers front and rear; cruise control; 70L fuel tank. Castor corrected Radius Arms, rear panhard rod raised mount, steering damper; bash plates transfer, radius arm, shocks, dual batts, headers, winch, rock sliders, custom aluminium roof rack on fitted tracks, Atoto head unit, LED headlts & HID 7" driving lights; 105Amp alternator to feed all the lights.
Post Posted: Sat Dec 23, 2017 1:17 pm
That's for M13A engine
Users browsing this forum: Google [Bot] and 235 guests
