It is currently Sun Oct 25, 2026 11:15 am
Post Posted: Sat Jan 03, 2015 10:00 pm
So I have a trimatic torque converter that is full of some fucked oil and I need to get it cleaned out before it goes into the new replacement auto.
Any ideas?? Soak in degreaser and drain a few times?
Post Posted: Sun Jan 04, 2015 7:57 am
Was watching extreme 4x4 on powerblock the other day and they just drilled a hole to drain then fitted a pop rivet.
Never seen that one before so can't really say I'd recommend it.
Post Posted: Sun Jan 04, 2015 8:03 am
Plenty of youtube clips about this, but all I've seen show a process for flushing with the converter in place in the gearbox and fitted to the car. Basically idle the motor, and drain the hose to the external cooler while pouring new ATF in the filler. When the draining fluid looks new switch off and button up.
Post Posted: Sun Jan 04, 2015 8:14 am
Could you link me to that Jason??
I don't want this oil in the auto at all... Its metallic
Post Posted: Sun Jan 04, 2015 9:02 am
How do you know it's a good converter then?
Post Posted: Sun Jan 04, 2015 9:33 am
It was working fine.. The auto its self was fucked. Hence replacement
Vehicle: Sierra
Post Posted: Sun Jan 04, 2015 9:38 am
I worked as a transmission builder for a Ford dealer for 4 years, definitely don't flush it in the car , best way is to drill a 1/4 hole in the back and flush with and evaporating solvent. Nothing blends with Auto fluid and will destroy the orings and clutch plates in the box eventually.
Personally I would pay for a new/reco convertor
Post Posted: Sun Jan 04, 2015 10:00 am
Thanks for that, what exact location should I drill exactly??
Unfortunately time and money restraints say no to a replacement.
Post Posted: Sun Jan 04, 2015 6:10 pm
Sorry no link, can't even remember what else was in that episode so not much chance of finding it.
Was just a matter of drilling a 3/16th hole in the outer of the TC near one of the flexplate mounting bosses and after draining fitting a blind rivet with a dob of rtv.
Users browsing this forum: No registered users and 150 guests
