It is currently Sun Oct 25, 2026 2:58 pm
Vehicle: SJ 80
Post Posted: Tue Jan 13, 2015 3:20 am
is it possible just to reduce the ratio gears for the T case of the 4L and keep the same ratio for 2WD and 4H - I'm asking this as I use my SJ as a day to day drive and for some crawling in the weekends. And does any one suggest a particular ratio that will be ideal for this type of use given I have standard shafts & will be running a 4xfour Art Kit in the coming weeks.
Post Posted: Tue Jan 13, 2015 5:30 am
Fit a leafy transfer case then you have a wide variety of reduction gearsets available.
Check out www.lowrangeoffroad.com they have a chart on the website that shows all the different ratios available.
Vehicle: Suzuki Jimny 2003
Post Posted: Tue Jan 13, 2015 6:50 am
is it a simple unbolt 1 and bolt in the other?
Post Posted: Tue Jan 13, 2015 8:26 am
You need a WT (sj70) jackshaft and mounts. Then its a bolt in.
Post Posted: Tue Jan 13, 2015 9:04 am
But it will lower high range.
I think Apio in Japan offer replacement planetary gears which will only lower low range. Expensive and not that low from memory.
Post Posted: Tue Jan 13, 2015 11:16 am
Is that to suit the coily transfer steve?
Post Posted: Tue Jan 13, 2015 11:27 am
I believe so, but the whole APIO thing is a pain to deal with.
Post Posted: Tue Jan 13, 2015 11:47 am
Seems a bit redundant considering anything bigger than a 215 is going to throw the high range gearing out of whack.
Vehicle: SJ 80
Post Posted: Tue Jan 13, 2015 5:07 pm
Thanks guys but is seems that the only way us to change the t case. .. but that will be lower the 4H & 2wd
Post Posted: Tue Jan 13, 2015 6:14 pm
Correct. But only by a small percentage. Depending what tyre size you are running/what gears you get it may well bring it back to standard in high range.
Users browsing this forum: No registered users and 134 guests
