| Author |
Message |
Tonner
Joined: Thu Oct 23, 2014 2:14 pm Posts: 87 Location: Calamvale
Vehicle: Sierra
 Posted: Thu Jan 22, 2015 7:22 pm |
Probably a stupid question but here goes anyway, if I fit a 2" suspension lift is there anything else that should be changed apart from the springs and shocks? Its going into an SJ70, I already have new bushes and shackle pins.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13001 Location: Melbourne
 Posted: Thu Jan 22, 2015 9:53 pm |
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5935 Location: Northcliffe, W.A.
 Posted: Thu Jan 22, 2015 11:24 pm |
It's a good idea to get some new U bolts.
Tonner
Vehicle: Sierra
 Posted: Fri Jan 23, 2015 6:07 pm |
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8135 Location: Sunshine Coast Qld
 Posted: Sat Jan 24, 2015 9:42 am |
After fitting new suspension, flex the car up and check that the brake flexi hoses aren't stretched tight. You may need to fit longer hoses.
Tonner
Vehicle: Sierra
 Posted: Sat Jan 24, 2015 6:45 pm |
want33s wrote: After fitting new suspension, flex the car up and check that the brake flexi hoses aren't stretched tight. You may need to fit longer hoses. All good, though a prick of a job by yourself
Tonner
Vehicle: Sierra
 Posted: Sat Jan 24, 2015 8:20 pm |
Question the suspension is now pretty hard and Im guess up in the spine wrecking area, can you take leafs out to soften it up? It has 5 leafs in the front and Im seriously thinking about removing one.
sideways
 Posted: Sat Jan 24, 2015 9:23 pm |
Yep, remove the lower ones first.
want33s
 Posted: Sun Jan 25, 2015 6:10 am |
Tonner wrote: want33s wrote: After fitting new suspension, flex the car up and check that the brake flexi hoses aren't stretched tight. You may need to fit longer hoses. All good, though a prick of a job by yourself Do you mean bleeding the brakes after replacing the hoses? I use a couple of metres of aquarium air line. Put one end on bleed nipple and the other in the master reservoir. Then pump the pedal till no more air comes out. Start with wheel closest to master and work out.
Tonner
Vehicle: Sierra
 Posted: Sun Jan 25, 2015 7:42 am |
want33s wrote: Tonner wrote: want33s wrote: After fitting new suspension, flex the car up and check that the brake flexi hoses aren't stretched tight. You may need to fit longer hoses. All good, though a prick of a job by yourself Do you mean bleeding the brakes after replacing the hoses? I use a couple of metres of aquarium air line. Put one end on bleed nipple and the other in the master reservoir. Then pump the pedal till no more air comes out. Start with wheel closest to master and work out. No sorry mate I meant fitting the springs.....lol....... I bought a one man bleeder gizmo a few months back and it works a treat provided you don't loosen the bleed screw to far.
Tonner
Vehicle: Sierra
 Posted: Sun Jan 25, 2015 7:45 am |
sideways wrote: Yep, remove the lower ones first. so by lower do you meen the shortest ones first
fordem
Joined: Mon Apr 19, 2010 11:30 pm Posts: 2656 Location: Georgetown, Guyana
Vehicle: JB420, APK416, A6G415, A6N415
 Posted: Sun Jan 25, 2015 7:57 am |
want33s wrote: Put one end on bleed nipple and the other in the master reservoir. Bad idea - REALLY BAD IDEA. The fluid coming out of the caliper/wheel cylinder is almost always contaminated with rust & dirt, you're putting that back into the braking system - you're also risking introducing what is known as "entrained air" - tiny microscopic bubbles that will eventually coalesce into larger bubbles and you'll be right back where you started - needing to bleed the system again. Also - brake fluid is hygroscopic - it absorbs moisture from the air - and needs to be replaced every few years, why not take the opportunity to pump fresh new fluid from a sealed container through the system, flushing out all the contaminated fluid and be done with it.
want33s
 Posted: Sun Jan 25, 2015 7:15 pm |
OK so I forgot to say to discard the first flush of fluid. Goes without saying doesn't it?
If bleeding after replacing lines most of the system will be empty so no worries about water absorption.
As for "entrained air" , you only get that in a pressurised system. With bleeder valve open there is virtually NO pressure in system even when pumping pedal.
