It is currently Sun Oct 25, 2026 12:14 pm
Vehicle: Suzuki Jimny 2004
Post Posted: Sun Jan 25, 2015 3:27 pm
So im planning on running some 215/75/r15 muddies and was wondering if the tyres will fit with stock height without scrubbing or will i need a 2'' lift.
Vehicle: Suzuki Jimny 2009
Post Posted: Sun Jan 25, 2015 3:43 pm
Chris, they will fit. Some report minor scrubbing with no lift and others say they are fine. Remember that unless you change your bump stops or cut the guards the lift does not give you any more clearance under full suspension travel. However the 215/75/15 will fit under the guards without doing either of these. I think they do look better with a small lift though.
Mike
Post Posted: Sun Jan 25, 2015 3:51 pm
Yeah planning on getting a lift just saving $$$ at the moment is the key for me at the moment (uni) so maybe i'll just save a little more and get both at the same time
Vehicle: 2012 jimny
Post Posted: Sun Jan 25, 2015 4:43 pm
I ran 215/75 mud tires on my jimny at stock height for 30000km's with no issues. Only time it would scrub was when the steering was at full lock going in reverse with some wheel articulation and even then i would call it more gentle and delicately kissing rather than scrubbing
Post Posted: Sun Jan 25, 2015 7:03 pm
right, but it will give you the clearance you need for day to day driving :wink: plus a bit of clearance before starting to hit the "scrubbing" part of the suspension travel.. so you won't scrub that easy unless you full flex.
..kinda what I need now with my 235s.. can't hit a small bump with speed without scrubbing everywhere
Users browsing this forum: No registered users and 182 guests
