1: Yes - my rear floater conversion runs vitara stubs & hubs and Jimny Rotors. There is a difference in rotors between VVT and non-VVT jimny - the center bore is different (or was it sierra and jimny? not sure) - check my build thread (search "The UFO" and "Floater") for details, i'm sure i posted it.
Sweet thanks - Exactly what I am doing - will be running vitara stubs and hubs on all corners was not sure if I was meant to keep the Jimny rotors on the front or get vitara ones as well - did you use Pintara Calipers?
Pintara calipers and swift GTI handbrake cables with a custom botched attachment to the sierra handbrake =)
Just really check those bores on the rotors that they're a snug fit.. The other type (jimny / sierra) is 1mm larger from memory - so its held by the studs rather than the hub which isn't ideal...
Users browsing this forum: No registered users and 107 guests
