It is currently Sat Oct 24, 2026 6:43 am
Vehicle: hkbjk
Post Posted: Tue Feb 24, 2015 7:14 pm
99 Jimny has begun to get a very horrible metallic squeal when under throttle. Squeal picks up with acceleration, no squeal when stationary.
I originally though it might have been breaks however sticking head out while driving sounds like it is coming from central under the car.
Book on one drive shaft was gone so I pulled that apart and found a badly worn CV joint which i could do nothing with but clean, re-grease and re-assemble. There is alot of clunking when crawling forward from stop and I believe that this worn CV is the cause of that but not this squealing noise.
I changed oil in Diffs, Transfer and Gearbox.
My only thought is it could be a wheel bearing, but I jacked the rear and spun the wheels and have been unable to replicate the noise.
Is it correct that the Jimny has a belt driven transfer? if so could the noise be originating from that and does that tie into it happening under throttle?
Any other suggestions on things to check or test to perform to find the cause of this?
Post Posted: Tue Feb 24, 2015 7:23 pm
Get a new cv/driveshaft.
i would start here, that cv does not look good/smooth/quiet etc
Jimny has chain driven xfer, they can stretch.
Vehicle: hkbjk
Post Posted: Tue Feb 24, 2015 7:28 pm
The reason I did not bother with replacing the CV/Driveshaft is because I have a sierra transfer to put in and it will do away with that joint anyway, The same thing if it is bearings I have a rear FF nearly ready to go on so at the moment I am just trying to work out what the noise/problem is and see if I can do a temp repair or if I have to speed things up for these other mods. Same grooves on the other part of that joint too:
Vehicle: hkbjk
Post Posted: Tue Feb 24, 2015 7:29 pm
What would be the result of a stretched chain? would it produce such a noise or have some other effect?
Users browsing this forum: Google [Bot] and 130 guests
