It is currently Sat Oct 24, 2026 3:52 pm
Vehicle: suzuki sierra
Post Posted: Thu Mar 05, 2015 11:05 am
ive just wired up a digital clock but its on all the time.i need a diagram or help to wire it to accessories or ignition I don't know to use accessories or ignition which one is best..the digital clock has 2 wires red and black.thanks
Vehicle: Which one?
Post Posted: Thu Mar 05, 2015 11:13 am
Wire it to accessories. Also, you don't really need a wiring diagram. Do you have a multimeter or a test light? Just find the nearest ACC wire and tap in to that.
Post Posted: Thu Mar 05, 2015 11:48 am
If the clock has only two wires, you'll have to leave it on all the time - unless - you plan on setting it every time you turn the key to on.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Mar 05, 2015 12:02 pm
that sounds like so much fun.
just grab the pos from the ciggy lighter for the acc signal, if it has one
Post Posted: Thu Mar 05, 2015 6:16 pm
since the clock only has 2 wires .wiring into accessories the clock ` will have to be set every time the accessories is on.is that right .thanks
Vehicle: '94 suzuki maruti
Post Posted: Thu Mar 05, 2015 8:58 pm
correct. i doubt these clocks pull much power though...
Users browsing this forum: No registered users and 83 guests
