[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
andrew
Vehicle: 92 suzuki sierra
 Posted: Fri Mar 27, 2015 9:40 am |
Hi guys my zook project came with a stuffed clutch Ive been looking on ebays and am not sure if I should get a Stock one or pay tge extra for a heavy duty one.
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Fri Mar 27, 2015 9:45 am |
If u got gearing stock is fine otherwise exedy hd is probably the nicest hd
jdk81
Joined: Sat Jul 18, 2009 11:30 pm Posts: 2372 Location: Ballarat, VIC
 Posted: Fri Mar 27, 2015 10:17 am |
Stock clutch is fine
It works fine behind the 1.3, and up to a 1.6 efi. More gearing means you dont need a HD clutch Bigger tyres and stock gearing, means you may need more clutch slippage, more clamping force here isnt really helpful.
HD clutch can cause clutch cable issues etc. Costs more, and not needed.
I was dumb enough to buy one early on, ran it for a while and got rid of it. I didnt have too many cable issues, but the pedal force was too much for the missus. I went back to stock, prior to switching to auto.
suz_rolly
Joined: Thu Jun 20, 2013 11:57 am Posts: 197 Location: Nanango Qld
Vehicle: Suzuki Sierra Lwb
 Posted: Fri Mar 27, 2015 12:06 pm |
Do not get the hd I've had one for 5 years broken4 cables bent and cracked a clutch peddle and I just found cracks in my firewall so don't get one, standard is what everyone else runs
BigRay
Vehicle: 1999 Suzuki Jimny JLX
 Posted: Fri Mar 27, 2015 3:59 pm |
Dunno what clutches you guys have had because I have a new Exedy HD Sports Tuff clutch in my 99 Jimny and love it. The pedal is waaaay lighter than stock and bites really nicely. I wouldn't have any other clutch! I am also running 215/75/15 mud tyres too.
Ray
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Fri Mar 27, 2015 5:22 pm |
I run a wrecked jimny clutch in mine (i'm on the 2nd wrecked jimny one now) i think it's from the M series engine ones (they have different splines between models and only 1 matches sierra). Anyway - that jimny clutch is the same clamping pressure as a sierra HD exedy clutch. And exedy list the same part numbers for replacements for Jimny & Sierra - so anyone buying a standard duty exedy for their jimny will have LESS pressure than their factory clutch had.
I've only snapped one clutch cable in the time i've owned my zuk, and it was the original factory one, and it failed at the end-bit that hooks onto the pedal (it wore through).
I think snapped cables are due to the cables not being lubricated or being overtightened.
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Fri Mar 27, 2015 7:03 pm |
Correct gearing. Standard clutch. No dramas.
_________________ mlm
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 65 guests
