What is the difference between the filters? When did they change? Can you chuck the one with screws in the clip air box? If not, can you change the intake/airbox?
A1351 (clips) is around $50-$80 A1357 (screws) is around $10-$25
Slight change in size whereby the 2 are incompatible. Changeover was 94 with the newer models getting the A1357. Changeover coincides with the later AFM and ecu etc.
Users browsing this forum: Google [Bot] and 355 guests
