It is currently Fri Oct 23, 2026 7:54 pm
Vehicle: 1998 suzuki sierra
Post Posted: Tue May 19, 2015 8:56 am
hey guys, just wondering what speeds you get out of your sierras that are running a standard 1.3L engine with bigger tyres. and how you went about it. i have a SJ80 sierra with a 2 inch lift and standard engine and extractors. and stock tyres cheers
Post Posted: Tue May 19, 2015 9:02 am
You can do 110/km/h with 31 on stock transfer gears, in 1.3L leafy - but it's super harsh on engine
Get some transfer gearing.
It depends on hills, headwinds and how heavy you run.
A better question, would be what's the biggest tyres you can reliably run on coily front diff before limited by the coily shittyness
Post Posted: Tue May 19, 2015 9:36 am
The trolley tug used to have no problem at 100km/h on 35.5" swampers. It's all in the gearing.
Post Posted: Tue May 19, 2015 10:02 am
How do i go about gearing it to get more speed out of it ?
Post Posted: Tue May 19, 2015 10:09 am
You're asking the wrong question. The question is "I have xx sized tyres. How do I gear the car back to standard"
As you have a coil Sierra, you will need to swap to a leaf sierra transfer case. These have a 1.409 or 1.58 high range, which is about 7% and 12% reduction over your chain drive case. From that point you can swap to reduction gears to offset even larger tyres.
There are no alternative diff gears for your model. All reduction needs to be in the transfer case.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Tue May 19, 2015 10:36 am
custom geared portals.
Post Posted: Tue May 19, 2015 10:38 am
When mine was still a 1.3L and running 215/75r15 tyres, extractors with 1.5" pipe and 2" lift I had no problem getting the needle off the speedo (about where 160km/hr would sit if it were on there). If your engine is tired that's a very likely cause for your current setup not getting you up to speed... no amount of gearing is going to help a worn engine =) lol
Post Posted: Tue May 19, 2015 10:48 am
Depends on the wind ;)
Post Posted: Tue May 19, 2015 12:00 pm
your telling me you got a sierra to 160km/hr?.... mine does 120 max and thats scary
Vehicle: WT sierra, GU CRD
Post Posted: Tue May 19, 2015 12:15 pm
When I first got mine I got it to about 130 or so, downhill with 4 people in the car :lol:
I love ZD30. :)
Post Posted: Tue May 19, 2015 1:29 pm
Well, I can't confirm that speed... as it was off the speedo and I was running larger tyres... but i got a speeding fine for 134km/hr in a 90 zone about 500m later (I was slowing down because there's often a camera in that area) lol
I've had my current setup at a confirmed 141km/hr (on the GPS) at 5200rpm. Not sure about everyone else's sierras but mines more stable / drives nicer at 110km/hr+ than it is at 100km/hr.
Vehicle: sj51
Post Posted: Fri May 22, 2015 8:00 pm
mine sits on 100 on 33's as long as its flat road and no headwind
I'm back..... Again
Post Posted: Fri May 22, 2015 9:13 pm
80ish kph flat to the boards on 38's on the flat with no wind at all and enough room to wind the hampster up. Mine was geared fairly low though.
Post Posted: Fri May 22, 2015 11:35 pm
:) will have to have a drag race with the new set up in yours sometime
Post Posted: Sun May 24, 2015 8:10 pm
Sure will, with the bigger swaybar in it it handles really well flat out on the speed section now.
Users browsing this forum: No registered users and 130 guests
