It is currently Fri Oct 23, 2026 10:59 am
Vehicle: 2000 Jimny
Post Posted: Sat May 23, 2015 4:51 pm
looking at getting a new battery for my jimny, tossing up between the Exide X60DPMF & Optima D51.
i'm interested in the exide after what sideways posted here:
viewtopic.php?f=4&t=48296
price is about $100 different between the 2 batteries but that doesn't really concern me.
i want to add a 6000lb winch at some point & don't really have any other taxing electrics, but if either battery would, it'd be great to be able to run my 40 litre fridge/freezer overnight & still have enough juice left to start the car in the morning (not essential).
http://www.optimabatteries.com/en-us/sh ... e-battery/
http://www.exidebatteries.com.au/batter ... me/x60dpmf
so what are peoples thoughts on these 2 units ?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sat May 23, 2015 9:46 pm
I have a optima. Cant fault it. For long drives on corrugated roads id prefer a spiral cell agm over a conventional plate.
Post Posted: Sun May 24, 2015 8:41 am
I got an optima from a wreckers 5 years ago, for $40.
It is still a kick ass battery.
Previously I had the biggest exide battery I could fit in the sierra.
After a year it failed due to vibrations.
The optima also recovers easily from being flat.
Optima are have a good rep for a reason.
Vehicle: 2000 Jimny
Post Posted: Sun May 24, 2015 10:04 am
how do you guys get on winching with it ? i don't really want to fit dual batteries but would like to be able to do a self recovery with it if possible. was also thinking about a 4500lb winch just for the lower power consumption but then it may not get me out of trouble. seems i'm in a bind.
Post Posted: Sun May 24, 2015 10:09 am
Graphic - A d51 is fine for winching - They have very low internal resistance. Winching is less about the battery and more about the alternator though. My D51 winches just fine.
A 4500b winch is false economy if you're trying to minimise total current draw. A small winch at high load and low speed will consume more power to get the job done than a faster winch with a higher load rating.
The old 6K warns were about as efficient as a winch gets up to 6K.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sun May 24, 2015 1:08 pm
Steve has a point. Put in a falcon 100A alternator and a d51 and youll be laughing with a larger winch
Vehicle: 2000 Jimny
Post Posted: Sun May 24, 2015 3:50 pm
thanks guys, i've looked at the falcon alternator but worried about loosing the fan for an electric one. also read about the lancer alternator that may drop right in & provide a decent boost.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sun May 24, 2015 4:03 pm
Fan? Falcon one practically bolts right in just need bracket mods and a few longer bolts.
http://auszookers.com/forum/viewtopic.php?f=5&t=35944
Vehicle: 2000 Jimny
Post Posted: Sun May 24, 2015 5:13 pm
from what i read it was a case of V belt, V pulley, alternator bracket & thermo fan. might have to have a re-read, it's something doable as i'm replacing the water pump in near future (already have pump & coolant sitting there waiting).
Vehicle: 2000 Jimny
Post Posted: Sun May 24, 2015 5:15 pm
just checked your link, unfortunately that's for M series, i've got G.
Post Posted: Sun May 24, 2015 5:30 pm
Read the whole falc alt thread.
That option is for g13a/g13ba who decide to use swift wp, and swift wp pulley, with the swift crank.
The wp pulleys off g16a are the ones you want, so you can keep the mech fan.
and sierra alt bracket
^both options wont work when g16b or g13b/g13bb due to wider timing belt
On a jimny, you already have multi rib pulleys.
All you need to do is mod the bracket and bolt it up. If it cant be modded, you need a vit/swift 1.6 alt bracket.
I just put a falc alt into my baleno.
Baleno alt bracket was different , and the baleno slider bracket didnt work either. I used a vit/swift 1.6 alt bracket, and a modified top slider bracket from a vit.
You can even use the stock size belt.
So much electrical goodness
Vehicle: 2000 Jimny
Post Posted: Sun May 24, 2015 5:44 pm
aren't the guys saying without the V belt the belt will slip though ? from what i read is that changing to the V belt is what leads to changing the pulleys, then the loss of the fan. i'll have to give it a re-read through as i can get hold of those alternators for nothing.
Post Posted: Sun May 24, 2015 5:53 pm
Will slip with the v belt.
Multi-rib belts take much more load before slipping.
The dicking around is due to sierra v belts and the offset wp pulleys, and possibly the different bolt pattern on harmonic balancer the 8v engines have.
16v engines are all multi rib and its only the alt bracket and slider bar thingo that need tweaking/swapping etc.
Vehicle: 2000 Jimny
Post Posted: Sun May 24, 2015 6:02 pm
alright thanks, will hit my mate up for one of his alternators & read that thread through to ensure i can knock it over.
Users browsing this forum: No registered users and 134 guests
