Vehicle: Suzuki Sierra
Posted: Sun Jul 12, 2015 6:29 am
About to put a lift into my sj50,2 inch leaves with a set of rancho 9000l shocks. I belive the shocks are 2-3 inch extension over standard. Not sure if extended bump stops will be required. Will the shock allow for all that up travel of the axle to the standard bumpstop or will it bottoms out on compression. And potentialy later on putting 215 75r15 a/ts or 235 75r15 m/ts i dont see a problem will the 215s hitting the gaurds under full flex. But if i decide to go with the 235s will i need extended bump stops to limit uptravel? Any input appreciated cheers.
Joined: Sat Feb 04, 2012 7:11 pm Posts: 1105 Location: Oberon, NSW
Vehicle: Drover pickup turk
Posted: Sun Jul 12, 2015 11:22 am
215/75s will be fine, 235/75s MAY have light rubbing on chassis, battery indent at the top of drivers guard and springs, All dependent on wheel offset.
As for the shocks, they will be something you need the flex the car up and measure the distances between the shock mounts and compare that to your shock length compressed.
Users browsing this forum: No registered users and 132 guests
